924 n/a flywheel cross section & lightening
Benino
PostPosted: Tue Dec 04, 2007 6:28 pm    Post subject: 924 n/a flywheel cross section & lightening Reply with quote
I made a scale diagram of the cross section of the 924 n/a flywheel.
I'm planning to have mine lightened. Here is the cross section. The light gray areas are the parts I'm thinking of having removed. I think that whole area and all the way to the end is just for weight purposes, not for strength. part of the friction surface to the inside of that, is already that thin. I think the area closer to the center (which is thinner) would need more strength since it has to be able to handle the centrifugal force of the mass of the rest of the flywheel.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
!tom
PostPosted: Wed Dec 05, 2007 7:29 am    Post subject: Reply with quote
There's also the heat capacity of the flywheel to consider. The majority of the mass that you're planning on removing is adjacent to the friction surface of the flywheel. Removing this will cause the temperature of the flywheel to increase over an un-modified flywheel when operating the clutch, due to the reduced heat capacity of the flywheel.
If your driving style is clutch friendly, this would probably not be an issue. However, I wouldn't be surprised if a lighter flywheel would lend itself to more clutch slipping than a conventional flywheel, and consequently that much higher temperatures.
Just something to consider. . .
78 924 NA
5-lug
PostPosted: Wed Dec 05, 2007 6:21 pm    Post subject: Reply with quote
I had my flywheel lightened. The took 1,5 KG of the back (engine side). This safe and won't effect the strength.
Ofcourse you can get more of it (by putting holes in it). But you will loose strength.
937 DITC
PostPosted: Thu Dec 06, 2007 3:57 am    Post subject: Reply with quote
So you removed material from the same area as in the pic above?
AppleBit
PostPosted: Tue Mar 11, 2008 2:14 am    Post subject: Reply with quote
Ever get it lightened? Otherwise I'll sell ya one dirt cheap... PM me if interested.
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
Martijnus
PostPosted: Tue Mar 11, 2008 2:45 am    Post subject: Reply with quote
I've heard some stories from people who took too much off... a shattered flywheel isn't fun... so keep limits in mind
interesting thread however... I'm not interested in weight loss in this case but you never know how I think about it in a few yrs
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
AppleBit
PostPosted: Tue Mar 11, 2008 2:50 am    Post subject: Reply with quote
Yeah, the shop that took the weight down recommended only so far. I told them to do what they thought was safe.
Result:
AppleBit
PostPosted: Tue Mar 11, 2008 2:52 am    Post subject: Reply with quote
took it down to 15 lbs. Honestly that doesn't sound like much, but its WHERE the weight was taken off. Made a bit of a difference. The only thing better is an aluminum flywheel (I have one left for sale) - either which way a great way to add power.
Benino
PostPosted: Tue Mar 11, 2008 2:59 am    Post subject: Reply with quote
Yup. I had mine lightened. Its back in the car and working fine. It looked pretty much exactly like the picture AppleBit posted. I'm pretty sure I took some pictures of it before I installed it, but I have on my home PC.
I did pretty much exactly what I have in my cross section diagram.
Nobbi
PostPosted: Tue Mar 11, 2008 3:00 am    Post subject: Reply with quote
Whats the positive effect of a light-flighwheel ?
NA 924 - april/1977- 4-speed-audi gearbox.
500.000 km with fun.....and new toy:Porsche 944 S2 Cabriolet.Other car Daimler c-class cabby,brandnew!
Plus new in the stable..1982 NA in grand prix white.Plus : DEUTZ 4005 tractor Built 1969
AppleBit
PostPosted: Tue Mar 11, 2008 3:02 am    Post subject: Reply with quote
+ Faster revving engine
+ Easier on the engine
- Loss of torque (minimal)
- Has to be done right or BOOM!
Martijnus
PostPosted: Tue Mar 11, 2008 3:10 am    Post subject: Reply with quote
what do you mean by "easier on the engine" ... the flywheel smoothes out the peaks in an engine iirc, especially when idling.
AppleBit
PostPosted: Tue Mar 11, 2008 3:14 am    Post subject: Reply with quote
If you had a 25 lb weight or a 5 lb weight, and you were swinging it around with your arm, what would be easier?
Another idea with the less weight is it can then consume less fuel... Now this all is more like a variable along with other things....
Benino
PostPosted: Tue Mar 11, 2008 3:35 am    Post subject: Reply with quote
any decrease in weight of the rotating drivetrain parts is going to mean less power lost between the engine and the wheels.
Rich H
PostPosted: Tue Mar 11, 2008 3:41 am    Post subject: Reply with quote
Did you guys balance them afterwards?
