Posted: Thu Nov 15, 2007 7:12 am Post subject: Remove balance shaft sprockets without a pin spanner. |
Conventional wisdom says to use a pin spanner to hold the balance shaft sprockets when you loosen the bolt. I am not conventionally wise.
You will have to remove the sprockets to replace the seals, or to take off the rear timing cover. (necessary for removal of the water pump)
My solution was to hold the sprocket with an old timing belt. You can make a strap wrench out of the belt and a pair of vice grips.
You must use only an old belt for this job. The belt can rip under the force of loosening the nut.
If the belt breaks you can use large chanel lock pliers to hold the sprocket, using the old belt to proctect the teeth of the sprocket. This works a little better than the strap wrench method if you have a big pair of pliers and room to use them. (it may be a little harder to get them over the bottom sprocket than the top)
_________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Thu Nov 15, 2007 9:55 am Post subject: |
I think a pin wrench would work too... _________________ 1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways |
