Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Wed Nov 14, 2007 5:53 pm Post subject: lower the rear by re-indexing the torsion bars |
I want to lower the rear by reindexing the torsion bars. A read this article on the forum:
http://www.924board.org/viewtopic.php?t=19005&highlight=torsion
But I assume if I dont't want to swap the torsion bars it is far less work ?
Has anybody done this before, and how much tooth do have to re-index the bars ?
My cars has -30 mm lowering springs in the front. _________________ 937 trackday car
Posted: Thu Nov 15, 2007 1:53 am Post subject: Re: lower the rear by re-indexing the torsion bars |
| Dutch924-racer wrote: | | But I assume if I dont't want to swap the torsion bars it is far less work ? |
wrong....its the same....do a search on the board...i have a thread and as i remember...i also droped some howto notes and pictures. _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Thu Nov 15, 2007 2:27 am Post subject: |
. . .and a great theme song! _________________ Toofah King Bad
Posted: Thu Nov 15, 2007 5:58 pm Post subject: |
How many hours work is it ? I do have a car-elevator. _________________ 937 trackday car
Posted: Fri Nov 16, 2007 3:22 am Post subject: |
it depends on how skilled or lucky you are. Everybody has done it in about 3 trys. It took me 2 since i was mostly working alone. so i would say....16 hours. _________________ Supercharger and EFI kits
jesse wall
Posted: Sat Feb 02, 2008 10:24 am Post subject: reindexing t bars |
if this is a track car or even astreet car that is not a garage queen , then you can reindex in about 20 minutes , see 9 magazine fron several months back , requires cuttin a 2 to 3 inch hole in rocker outside the t bar carrier end plate , and drilling at least one t bar in place for 3/8 course threads if you are interested let me know Jesse _________________ jesse wall 'new driver' , 87 924s |
John Brown
Posted: Sun Feb 03, 2008 11:39 pm Post subject: |
ROTFLOL  _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
gone but not forgotten: original 924.org car - 82 |
jesse wall
Posted: Mon Feb 04, 2008 11:15 am Post subject: hey John |
what does that mean ? btw changed ride height on rear of my 924s last week with LT helping did not take anything loose , took 10 minutes for both sides , took longer to take off wheels and put them back than anything else Jesse _________________ jesse wall 'new driver' , 87 924s |
Posted: Tue Feb 05, 2008 12:03 am Post subject: |
But that is probely not by reindexing the torsionbars. _________________ 937 trackday car
jesse wall
Posted: Tue Feb 05, 2008 1:19 am Post subject: t bars |
yes that is pulling the t bars out and replacing them at a different ride height , it is very easy once you get the hang of it . of course both of my t bars are drilled and tapped for 3/8 course thread ,, ONCE AGAIN YOU NEED TO HAVE A 2 TO THREE INCH OPENING IN ROCER PANEL JUST FORWARD OF WHEEL WELL lOOK AT OLDER CARS CAME FROM FACTORY LIKE THIS it is really important to have a friend move hub while you reinsert the t bar , you need to see the splines but other than it is easy ! will be glad to email you pics or just go to 9 magazine the copy with the porsche designed boat on cover , this is online mag. Jesse _________________ jesse wall 'new driver' , 87 924s |
Posted: Wed Feb 06, 2008 1:52 am Post subject: |
Yes, I would like to receive some pictures. thanks. _________________ 937 trackday car
Last edited by Dutch924-racer on Sun Nov 15, 2009 10:08 pm; edited 1 time in total |
Matt Norton
Joined: 14 Apr 2006 Posts: 196 Location: Montour Falls/Watkins Glen NY
Posted: Wed Feb 06, 2008 5:22 am Post subject: |
Is this any different or easy on a 924S? How much of a difference in handlaing does it make and what is the disadvantage if you are rearended by an american car?  _________________ Red 1987 924S with plans for D Productions Kit
From American International Racing. |
jesse wall
Posted: Wed Feb 06, 2008 5:47 am Post subject: t bar |
my car is a 924s , you can set the ride height of the car however you like I would think getting rear ended by any largecar would result in about the same problems , that is not a Ralph Nader 5 mile and hour test but a real wreck . you will most likely trash your porsche or need a welding expert and a parts car _________________ jesse wall 'new driver' , 87 924s |
jesse wall
Posted: Wed Feb 06, 2008 6:12 am Post subject: handling |
not a lot of differrence instreet car with stock t bars , however if you up your front and rear spring rate , it really makes a lot of difference, becareful not to lowere your car so much that you run out of shock travel , thenthe handling will be dangerous, and not any ore pleasant than riding on a board, I like the 225 to250 lb springs in front and 25.5 to 27 mm tbar in rear , keeps the car fun on street still handles well on track _________________ jesse wall 'new driver' , 87 924s |
