fuel pipeand filter across top of the tank
Tiny
PostPosted: Sun Nov 04, 2007 5:33 am    Post subject: fuel pipeand filter across top of the tank Reply with quote
Hi Guys,
What's the purpose of this fuel pipe and plastic fitting that goes across the top of the tank?
thanks,
Tiny
*****1981 - 924 - Auto - London, UK******
PostPosted: Sun Nov 04, 2007 5:53 am    Post subject: Reply with quote
AFAIK it is just a vent line
3 928s,
johnathan1
PostPosted: Sun Nov 04, 2007 4:15 pm    Post subject: Reply with quote
Do you have a high-res version of that pic? I'm wondering if mine looks the same.
-1977 924, 4-Spd...Gone
-1987 Toyota Supra Turbo, Pearl White, BPU, 300RWHP @ 10psi.
-1989 Mercedes-Benz 300SEL
WARNING: MAY CONTAIN TRACES OF AUDI OR VW!
Tiny
PostPosted: Sun Nov 04, 2007 10:08 pm    Post subject: Reply with quote
Hi Johnathan,
Afraid not, as I didnt take this shot.
regards,
Tiny
John Brown
PostPosted: Sun Nov 04, 2007 10:53 pm    Post subject: Reply with quote
The plastic tube functions as an expansion tank. Whether it's absolutely necessary I've wondered about as it is not very much larger than the same length of hose.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
gone but not forgotten: original 924.org car - 82
Ozzie
PostPosted: Mon Nov 05, 2007 6:51 am    Post subject: Reply with quote
I had mine out last year and if it was cracked it would just have been a fuel line going across there.
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Mon Nov 05, 2007 7:21 am    Post subject: Reply with quote
What year of car was that tank from?
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
johnathan1
PostPosted: Mon Nov 05, 2007 10:28 am    Post subject: Reply with quote
I have a feeling that the hoses connected to that plastic tube are leaking on my car...I am guessing I will have to drop the tank to replace those lines?
PostPosted: Mon Nov 05, 2007 11:22 am    Post subject: Reply with quote
I can smell raw fuel from time to time on a full tank. I know that my sending unit is not leaking because i have lifted the cover when the smell was strong and looked at it. It was dry. If a 1987 924S has the above setup, that may be my problem.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
Ozzie
PostPosted: Mon Nov 05, 2007 1:16 pm    Post subject: Reply with quote
No- I did mine without removing the tank- look in the how-to section.
Cutting a hole is drastic but it worked.
johnathan1
PostPosted: Mon Nov 05, 2007 5:19 pm    Post subject: Reply with quote
WTF??? Is the fuel tank THAT hard to remove?
Ozzie
PostPosted: Mon Nov 05, 2007 5:30 pm    Post subject: Reply with quote
It is very easy to remove the tank.
You just have to remove the transmission and drop the exhaust first.
johnathan1
PostPosted: Mon Nov 05, 2007 8:19 pm    Post subject: Reply with quote
Right then...i'll go look for my tinsnips!
Ozzie
PostPosted: Mon Nov 05, 2007 8:52 pm    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?t=17851
