peebles24
Joined: 27 Jul 2007 Posts: 43 Location: Terre Haute, IN
Posted: Wed Sep 12, 2007 7:21 am Post subject: What speakers fit? |
Crutchfield says the 924 takes 4X6's in the front and rear. I haven't pulled the dash speaker cover off but it looks more like it will be a single dual voice coil speaker. Crutchfield also says there is six speakers in the car. I only see 3 locations.
What do you guys have in yours what fits well under the factory grills.
Thank You,
Chad P. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
968rz
Joined: 21 Aug 2006 Posts: 536 Location: S. E. Wisconsin
Posted: Wed Sep 12, 2007 8:11 am Post subject: |
They just give you all possable choices. When I checked my 24 it said the same as you (2-4x6 in frt, 2-6x9 in side, 2-4x6 in rear) this is wrong, from the factory I have 2-4x6 in rear and thats it. The dash speaker is for the mono radio (if anyone ever picked it) and is not there in my car (had original stereo). As my carpet is far from perfect I opted to cut it at the cubbies and install some 6x9s, this really improved the sound (still not the best but better)
Hope this helps
PS. they don't even list a 968, like it was never built _________________ Rick
79 924 coupe Petrol Blue 3spd auto (wife's DD)
93 968 coupe Amazon Green 4spd Tip (my DD)
02 Trailblazer Red 5spd auto (wife's winter car)
06 Jetta sedan Graphite Blue 6spd Tip (my winter car) |
Posted: Wed Sep 12, 2007 8:43 am Post subject: |
Mine got the 2 rear seat side 4x6's and a single 4x6 in the top-center dash spot. -And a fader control near the shift lever. The front-center and rear-left are on the same stereo channel.
The OE speakers were the simple oval single cone design. I replaced the rears with 4x6 plate speakers (they have a 4" round woofer mounted next to a small tweeter on a 4x6" plate). For the front, I used an oval 4x6 plate speaker with the tweeter suspended at front-center. I just had to trim the plate a bit to make it fit.
There were different speaker arrangements - some, like mine with the fader, used 4ohm at all 3 positions; while others, without the fader, used a mix of 8ohm and 4ohm speakers. _________________ "..it's made in Germany. You know the Germans always make good stuff."
924guy
Posted: Wed Sep 12, 2007 6:50 pm Post subject: |
my 82 was similar to smoothies, except both left and right front channels play through the single dash speaker, yes both the plumbing is a mess, originally designated the "premium" sound system, and the rear channel is the same as all others, under the 1/4 windows on each side.
there is space for 4x6's in the doors, like the later models had.
if your going to stick with the 4x6's, polk or infinity plates styles work well, in my 82, i wired the three original speakers to the front channel, through the original wiring so the center speaker still carries both left and right channels via the fader, the wiring is a maze of spaghetti.. and used a set of 6x9 boxes in the hatch _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Mike924
Posted: Wed Sep 12, 2007 8:22 pm Post subject: |
These fit and they're Porsche factory fitment to current models. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
peebles24
Posted: Wed Sep 12, 2007 9:27 pm Post subject: |
The 60 ElCamino I used to have had a single speaker in the front. I replaced it with 2 3 1/2's, I used a piece of metal and two bolts to hold them together. I may try that in this opening. _________________ 1981 924 Weissach, progressive rate coils, Dansk Polished S/S exhaust, free flow Cat, K&N filter
1991 Toyota FJ80 |
