AGD931
Joined: 17 Mar 2003 Posts: 289 Location: Athens, Greece
Posted: Sun Aug 05, 2007 4:16 am Post subject: Windscreen gaskets |
This is my first "how to" so here goes...
I have never been a fan of the unsightly gap between the windscreen and the frame on 924's, I always had the impression that the factory forgot to fit something on the production line. My wife has even said to me on numerous occasions, "what is supposed to go in there?"
I have always enjoyed retrofitting "factory" improvements like this on all the cars I owned, I feel it adds to the pleasure of owning the car.
Well, I decided to do something about the windscreen frame and ordered the windscreen gaskets from the "first" 944's. The relevant part numbers are
944 559 027 00 - left gasket
944 559 028 00 - right gasket
Total cost for both 22 Euro.
Fitting them is very easy, I did it this way
- Clean windscreen glass around the edges where the gaskets will fit with a light alcohol. I used the wife's nail polish remover you may use your favourite brew if so inclined
- The gaskets have a light self-adhesive on one side protected by a plastic film. I did not remove this at first, as I trial fitted the gaskets in order to ensure correct fitment at the top windscreen moulding and at the bottom of the side mouldings.
- Having made the trial fitment, ensuring that the end of the gasket sits flush with the edge of the upper windscreen moulding, I peeled a small section of the plastic film at a time and then fitted the gasket merely by pressing it into the gap. The top of the gasket has a thin groove along its length which slots very nicely on to the edge of the side windscreen mouldings.
- Repeat the above for the other side, and enjoy a cold beer, (I was drinking cold coffee at the time..)
For some reason, the left gasket was about an inch longer than the right and hangs off the left moulding, I left it as it was as the rear edge of the bonnet conceals it.
As you can see from the pictures, the end result is definitely worthwhile and smartens up what is in reality a bit of an eyesore. I didn't "test drive" the new gaskets, but I think at high cruising speeds the gaskets will smooth out air turbulence around the frame. We'll see.
Arthur
 _________________ 1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia |
Posted: Sun Aug 05, 2007 5:48 am Post subject: |
very nice !
i bet that the big wooooooshhhhhhhh at over 100Km/h is gone now. _________________ Supercharger and EFI kits
https://www.the924.com |
endwrench
Posted: Sun Aug 05, 2007 6:49 am Post subject: |
Looks much better. This has been bugging me lately too.
Posted: Sun Aug 05, 2007 11:41 am Post subject: |
Great work. Thanks Arthur.
That really is an improvement. _________________ 1979 924 (Gone to a better place)
john h
Posted: Sun Aug 05, 2007 9:27 pm Post subject: |
looks good
I'm surprised that you didn't have them - both my Turbo's had the gakets, however the n/a I have don't have them but I know them have both had new windscreen's fitted - signs of broken glass in the car mainly in the vents, just figured teh windscreen guys were lazy (slack) and just couldn't be bothered refitting them.
I know when I had a new screen fitted to the GT replica I had to go back and make the installer search through the rubbish for those seals and also for the caps that go over the wipers bolts ( their response was they come with the screen and since I hadn't paid for the 944 screen I ddin't get them). _________________ Remember a Porsche is not just for Christmas,
Posted: Mon Aug 06, 2007 11:11 am Post subject: |
Yeah, I recommend these - installed mine about 2 weeks ago. Much cleaner look.
Cheers, _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
