if you can't find them, grind them???
wharris1178
PostPosted: Sat Aug 04, 2007 7:09 pm    Post subject: if you can't find them, grind them??? Reply with quote
ok just went on a little midnight drive tonight and still having problem with 1st and reverse, they want to grind everytime. So, I have to shut off the car and put it in 1st gear then start it with clutch pedal pressed down of course. all the upper gears don't grind, just 1st and reverse, is there some kind of adjustment somewhere or is the tranny fluid low? how do I change the fluid? god sometimes I wish I bought a 924 with an automatic.
2000 Cavalier Z24 imposter
84 Porsche 944 SOLD
79 Porsche 924 SOLD
Porsche, there is NO substitute. If you can afford one, lol.
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
Stampedetrail
PostPosted: Sat Aug 04, 2007 7:48 pm    Post subject: Reply with quote
Might need to adjust the clutch. The cable has 2 15mm(?) nuts on the bracket. You adjust them at the bracket to lengthen or shorten the clutch cable, might be worth a try to shorten it, but suppose the 1st gear synchro is worn out that might cause your problem too, which would require dropping the tranny. In the meantime, you can practice starting off in 2nd gear
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
endwrench
PostPosted: Sun Aug 05, 2007 6:40 am    Post subject: Reply with quote
First gear syncro is gone AND your clutch is out of adjustment or just coming apart.
Todd[/b]
PostPosted: Sun Aug 05, 2007 7:09 am    Post subject: Reply with quote
Stop the car, shift to second, then 1st or reverse.
wharris1178
PostPosted: Sun Aug 05, 2007 5:02 pm    Post subject: Reply with quote
where is the clutch adjustment at, god I hope its not under the dash like on my old chevys
84 Porsche 944 SOLD
79 Porsche 924 SOLD
michi924
PostPosted: Sun Aug 05, 2007 7:10 pm    Post subject: Reply with quote
Don't worry, it isn't under the dash. You can find the cable under the hood. It's just under the brake fluid reservoir tank.
Mike924
PostPosted: Mon Aug 06, 2007 5:30 pm    Post subject: Reply with quote
...that doesn't make it any easier to get to.
Alternatively, if you can't engage them, re-arrange them.
