Pilot bearing
Rich H
PostPosted: Mon Jul 30, 2007 9:29 pm    Post subject: Pilot bearing Reply with quote
Hi all,
Finally got my pilot/spigot bearing out with a dremel and a chisel and changed the torque tube for one that isn't totally messed up. The housing is slightly damaged but generally ok (there is no way in hell that it's is coming out!) so now I need to replace it.
Porsche UK have only one in stock in the entirity of the uk so I was hoping it was a standard SKF bearing.
Does anyone know the dimensions of it? Its a version 2 casing. I think I need internal bore, external diameter and the width of the bearing.
Any help would be greatly appreciated!
Cheers
Rich
Rich H
PostPosted: Tue Jul 31, 2007 7:55 am    Post subject: Reply with quote
The answer is 21mm OD 15mm ID by about 15mm best I can tell. SKF do several that will fit and they even include a lip seal built in at half the price of the Porsche one.
PostPosted: Tue Jul 31, 2007 9:25 am    Post subject: Reply with quote
Hey your good! You answer your own question plus leave behind useful stuff...
Rich H
PostPosted: Wed Aug 01, 2007 7:15 am    Post subject: Reply with quote
I do tend to talk to myself...
Rich H
PostPosted: Thu Aug 02, 2007 2:49 am    Post subject: Reply with quote
SKF: HK15162RS on order. 15mm bore, 21mm OD, 16mm long with 2 seals built in, £4 pick up tomorrow, I'll let you all know if it fits... fingers crossed!
Rich H
PostPosted: Fri Aug 03, 2007 7:14 am    Post subject: Reply with quote
Well it was £8 after tax, but fits nicely
Rebuild in progress...
Rich H
PostPosted: Sun Aug 05, 2007 1:39 am    Post subject: Reply with quote
Rebuild completed! Mostly :?
Won't start, but it was after 10pm and too dark to see what was wrong, pretty sure its sooty plugs as I suspect the crank breather is blocked
I've got to get to the UK National 924 meet tomorrow so I still have plenty to do...
Wish me luck!
PostPosted: Sun Aug 05, 2007 1:43 am    Post subject: Reply with quote
Hey! Good luck!
Rich H
PostPosted: Mon Aug 06, 2007 8:03 pm    Post subject: Reply with quote
Well, it started, and ran the 145 mile round trip to the 2nd UK national meet of the 924 owners club
Now I'm going to break it again to fit EFi....
