cegan09
Posted: Wed Jul 25, 2007 10:05 pm Post subject: Steering... |
Ok, so i'm to the point where i can pull my engine out of my 87 924S. However there are two things blocking me. I can't seem to get the steering arm out of the drivers side wheel, and the universal joint won't come off the pin or whatever it is that it attaches to just by the cross member. The steering arm practically fell out of the passenger side wheel, but i can't for the life of me get it out of the drivers side. The cotter pin and nut are off.
As for the universal join, i've pulled the bolt that clamps it down, and tried to wedge the slit open a bit. It still won't pull off though.
My question si does anyone have any tricks or suggestions to getting these out? Once this is done i have the cross member off and i can pull the engine off the torque tube and out of the car. _________________ 1987 Porsche 924s (summer project)
2002 Toyota Camry (practical daily driver) |
D Hook
Posted: Wed Jul 25, 2007 11:02 pm Post subject: |
Sometimes some penetrating oil over night and a few judicious taps with a hammer will loosen things up. Be careful of the threads. _________________ '80 924 n/a SOLD |
cegan09
Posted: Thu Jul 26, 2007 1:32 am Post subject: |
so no other suggestions besides some penetrating fluid and a hammer? (both of which i've tried) _________________ 1987 Porsche 924s (summer project)
Mike924
Posted: Thu Jul 26, 2007 1:40 am Post subject: |
penetrating fluid, a hammer and persistence...? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
Posted: Thu Jul 26, 2007 1:45 am Post subject: Re: Steering... |
| cegan09 wrote: | | The steering arm practically fell out of the passenger side wheel, but i can't for the life of me get it out of the drivers side. The cotter pin and nut are off. |
Talking tie rod ends here, right? Mine wouldn't budge until I went at it with an air hammer with fork attachment - used that and with the other hand a regular hammer to hit down on it. -But I was replacing them, not reusing. It still took a while even with the air hammer. _________________ "..it's made in Germany. You know the Germans always make good stuff."
-nick
Posted: Thu Jul 26, 2007 1:52 am Post subject: |
I've used a heavy hammer and whacked the crap out of them from the thread side. But I also was replacing when I did it. A ball joint fork might work well enough to be able to reuse them. If they're original though, why not just replace? They're pretty cheap. I'd be suspect of the one that just fell out anyway. _________________ 1980 931S
1991 964 C4 Cabriolet |
Raceboy
Posted: Thu Jul 26, 2007 2:53 am Post subject: |
If you plan on reusing the steering knuckle ball joint, then don't touch the ball joint nor down neither thread side. Instead hammer the mounting arm from the side and it will come off. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Thu Jul 26, 2007 3:54 am Post subject: |
I used a gear puller on my stubborn side. _________________ Toofah King Bad
endwrench
Posted: Thu Jul 26, 2007 4:46 am Post subject: |
| Raceboy wrote: | | If you plan on reusing the steering knuckle ball joint, then don't touch the ball joint nor down neither thread side. Instead hammer the mounting arm from the side and it will come off. |
Raceboy is correct. Put some pressure on the tierod with a prybar then give the arm a good wack with a hammer. Get someone else to pry while you hammer.
cegan09
Posted: Thu Jul 26, 2007 5:00 am Post subject: |
i have tried every combination of hammering, prying, soaking there is. Only thing i haven't tried is a gear puller. I'll attempt that then i get home.
Any suggestions for the universal joint that sits just above the cross member. I need to get it off the rack and pinion assembly so i can drop all that steering stuff. _________________ 1987 Porsche 924s (summer project)
924guy
Posted: Thu Jul 26, 2007 9:27 am Post subject: |
for the steering knuckle, i used an old screwdriver and pounded it into the slot to open it up it a bit, while pulling down on the rack (after unbolting.) took a bit, but came off with some effort. dont damage the splines or split the clamp...  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Posted: Thu Jul 26, 2007 10:33 am Post subject: |
On the steering U joint, one must remove the bolt completely, then loosen the rack from the cross member, and the U joint will usually pull right off of the steering shaft as the rack is lowered.
On the tie rod end, get two ball pein hammers and bang the sides of the steering arm, the tie rod end will pop out. If not, heat it then hammer again. _________________ White 87 924S "Ghost"
Posted: Thu Jul 26, 2007 1:43 pm Post subject: |
As Paul said with the U joint. The bolt sits in a groove and must be removed first. A large flat screwdriver used to open the clamped section slightly helps.
I have used a hot air gun to heat the steering arm from the nut side with a damp rag around the joint rubber. This expands the tapered hole just enough to loosen the tight fit. Use a plain nut if you have one on the stub and hit it hard square on the end. I use a copper mallet here as I have one. Suggest a heavy dolly (steel block) on the arm to prevent any further damage if it needs much bashing. But it DOES eventually separate!
Roger |
cegan09
Posted: Thu Jul 26, 2007 10:58 pm Post subject: |
Thank you for the suggestions. I still haven't gotten them off, but i have a few more ideas. Hopefully its off tonight. _________________ 1987 Porsche 924s (summer project)
D Hook
Posted: Thu Jul 26, 2007 11:01 pm Post subject: |
| cegan09 wrote: | | so no other suggestions besides some penetrating fluid and a hammer? (both of which i've tried) |
Bigger hammer?
Fire wrench?  _________________ '80 924 n/a SOLD |
