bureau13
Joined: 07 Sep 2017 Posts: 495 Location: South Florida
Posted: Mon Jan 29, 2018 3:14 am Post subject: Nervous about my timing belt tension |
I mean to give the old belt a twist before I took it off to "calibrate my twister" for that 90 degree twist method, but I forgot. So I ordered this Krikit thing from Gates, but it says it's for v-belts. Is this the same thing people are using? Or is there a similar device for toothed belts? If there is, I haven't been able to find it.
If it is the same thing...what tension am I supposed to use? Even Haynes says to use the 90 degree twist method.
Finally...I saw a post a while back about tensioning to pitch when you pluck it like a string. I can get a pretty consistent pitch measurement when I do that, I just don't remember what the correct value is.
For what it's worth, I can just twist the belt 90 degrees...maybe a bit more if I really put some effort into it. I just fear that's too tight for some reason... _________________ 1982 931
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2007 Hummer H3 (Timing chain guide failure)
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen) |
Posted: Mon Jan 29, 2018 4:58 am Post subject: |
I seem to always put mine on too tight and then back it off a bit after it's running and I can tell..
If it's too tight I will hear it, it'll sound like a toothy wine.. Reinstalling the belt I back it down till I just can't hear it or just barely.. With a brand new belt I'd back it down till I can only just hear it a bit and it'll wear in a little..
But I don't run a belt guard so adjustments are easy..
I can twist the belt too much by hand, probably could even if I maxed out the tensioner..
For a smaller guy I have strong hands from a lot of hand clutch and brake when I was young and ofcourse spinning a lot of wrenches..
I don't know what anyone else has to say about this sound method but I'd be interested to hear about more proper or better ways of doing it myself..
Putting a new cambelt on is one of my next steps, can't seem to find the baggie of my stripped TB parts ATM.. _________________ 80 Turbo - Slightly Modified |
Posted: Wed Jan 31, 2018 12:22 am Post subject: Re: Nervous about my timing belt tension |
| bureau13 wrote: | I mean to give the old belt a twist before I took it off to "calibrate my twister" for that 90 degree twist method, but I forgot. So I ordered this Krikit thing from Gates, but it says it's for v-belts. Is this the same thing people are using? Or is there a similar device for toothed belts? If there is, I haven't been able to find it.
For what it's worth, I can just twist the belt 90 degrees...maybe a bit more if I really put some effort into it. I just fear that's too tight for some reason... |
...just answering the frequency part...
http://www.924board.org/viewtopic.php?t=42614&postdays=0&postorder=asc&highlight=frequency&start=15
This car is still running just fine with the belt setting described in the above thread
This was done with an iPhone and a guitar tuning app. Just got the phone close and plucked the same section you twist. _________________ 1980 931 since 1989
bureau13
Posted: Wed Jan 31, 2018 12:34 am Post subject: |
Perfect! That's the exact thread I remember, for some reason I couldn't find it. Of course, I don't remember what the frequency I measured was, but I can easily go back and check (I took just about everyone's advice and left off the cover)
The other comment in that thread is interesting....everything I've seen about the twist method says 90 degrees...if I'm supposed to twist it to 180, that seems loose. Definitely looser than my belt right now... _________________ 1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Wed Jan 31, 2018 12:42 am Post subject: |
| bureau13 wrote: | Perfect! That's the exact thread I remember, for some reason I couldn't find it. Of course, I don't remember what the frequency I measured was, but I can easily go back and check (I took just about everyone's advice and left off the cover)
The other comment in that thread is interesting....everything I've seen about the twist method says 90 degrees...if I'm supposed to twist it to 180, that seems loose. Definitely looser than my belt right now... |
Off the top of my head 90 degrees sounds right not 180 but you will know when its too tight since it will hear it as mentioned by FastEddie
Better set too tight, listen and back it off a bit. CHeck the frequency too if you can and go from there _________________ 1980 931 since 1989
Posted: Wed Jan 31, 2018 1:25 am Post subject: |
Even if ive done it a couple of times its still hard, twist method sucks hard, it so easy to get it to tight. Frequency is so much better. Set it at 85hz last time with help of a frequency analyzer on the phone. I wish there were a workshop number to work with  _________________ 1980 924 Turbo
Posted: Wed Jan 31, 2018 5:14 am Post subject: |
| Cédric wrote: | Even if ive done it a couple of times its still hard, twist method sucks hard, it so easy to get it to tight. Frequency is so much better. Set it at 85hz last time with help of a frequency analyzer on the phone. I wish there were a workshop number to work with  |
So we are close...this was mine from the other thread
"New belt (931) with a few hundred miles on it so far... F2 (87Hz) "
We have our running baseline so far 85-87 Hz
As far as a workshop number, we might be able to contact the supplier and I think Conti is one that still makes the belt. They might be able to provide a number? Like I stated before for Ducati's, the suppliers actually published the number. _________________ 1980 931 since 1989
bureau13
Posted: Thu Feb 01, 2018 7:00 am Post subject: |
FWIW I sent an email to someone at Continental. I'm sure it will go nowhere, but you never know... _________________ 1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
bureau13
Posted: Mon Feb 05, 2018 2:18 am Post subject: |
For what it's worth, my twist method attempt had it set at 124 Hz. I backed it down to about 85 Hz. Honestly, how is this not the best method that everybody uses everywhere? _________________ 1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Tue Feb 06, 2018 1:09 am Post subject: |
| bureau13 wrote: | | For what it's worth, my twist method attempt had it set at 124 Hz. I backed it down to about 85 Hz. Honestly, how is this not the best method that everybody uses everywhere? |
exactly
The first time I did this was on a Ducati 748 which then saw near 13K on the track no issues.
This method doesn't lie and isn't affected by our own paranoia of wanting to get this right by feel.
Check it again after it runs for a while. It may relax a bit _________________ 1980 931 since 1989
Posted: Wed Feb 07, 2018 11:02 pm Post subject: |
Indeed the twist method is not accurate at all.
There is no way to calibrate for any individuals strenght or effort. I must have strong hands as can twist it throuh 180*, although not real easily, while another person may go blue in the face achieving 90*.
That`s probably the reason why porsche came up with their P9201 tool, it is calibrated in a specified unit of measurement and constantly repeatable. Same with the more basic Gates Krikit option. There are a few different models & ranges and are suitable for various size V belts, PK and other series multirib belts. Also works fine for timing belts where a figure is specified. I use the blue one that IIRC has the lowest range, down to 30#.
Many 944 & 928 guys use the Krikit sucessfully. There is no spec of tension or frequency for our 2L engines. IIRC the 944 timing belt spec is 30 or 32 Lbs and apparently also proven compatible on our engines. Recall reading some much earlier threads here or RL maybe 10 years ago, before getting the tool.
Mike9311, I looked into measuring frequency some time ago after that other thread. Don`t have a guitar tuner or iphone so downloaded Spectrum Analyzer Pro and some other useless program on my D630 tuning laptop but could not get any specific peaks at all. Notice you used a similar laptop so would like to know what software you used?
bureau13, As you also have the Krikit tool it would be interesting for someone to record and compare various tension readings with their resonant frequency. Just statically of course, don`t need to start the engine. _________________ World`s quickest 924 2L slushbox
| Allan @ DTA wrote: | | I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards |
Posted: Thu Feb 08, 2018 3:44 am Post subject: |
I was using it to build home speakers at the time.
https://www.trueaudio.com/rta_abt1.htm
It may be cheaper to buy a cheap guitar tuner off ebay
You can always look for speaker testing equipment but its overkill. For example...
https://www.parts-express.com/Search.aspx?keyword=testing&sitesearch=true
I am so glad I found this method back in the day. I even successfully pulled off the "twist method" on a 944S2 a long time ago but I can say I never liked it.
The more of us that try it and provide feedback the better. _________________ 1980 931 since 1989
bureau13
Posted: Thu Feb 08, 2018 4:41 am Post subject: |
I will try to do this over the weekend.
| RC wrote: | | bureau13, As you also have the Krikit tool it would be interesting for someone to record and compare various tension readings with their resonant frequency. Just statically of course, don`t need to start the engine. |
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
bureau13
Posted: Mon Feb 12, 2018 4:25 am Post subject: |
OK, for what it's worth, when I remeasured via the pitch method, I got 93 Hz, and on the Krikit, right at the low edge of the range, which is supposed to be 30 lbs. _________________ 1982 931
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Posted: Wed Feb 14, 2018 11:40 pm Post subject: |
Thanks bureau13 for measuring that.
The lowest graduation on the Krikit is 30#, which is where I set mine at.
Tried Frequency Counter android app briefly but without much sucess at all. Got a wide variety of different readings even on the much tighter 6PK blower & alt/WP belts. Intend playing around more another time with the settings for backgeound noise, time period & whatever and will post if I get some repeatable results. _________________ World`s quickest 924 2L slushbox
