Topend
Joes924
Guest
PostPosted: Thu Apr 25, 2002 10:51 am    Post subject: Reply with quote
Cam arrived at schneider on the 22nd.
http://home.attbi.com/~joedanka/porsche1/eurothrot.JPG
See I have the one with the sleeve still pressed in.
http://home.attbi.com/~joedanka/porsche1/stthrotbody.JPG
http://home.attbi.com/~joedanka/porsche1/topend.JPG
Ill use the big bore.
http://home.attbi.com/~joedanka/bigbore.JPG
924Porsche1979JoeD.
[ This Message was edited by: Joes924 on 2002-06-05 06:09 ]
Joes924
Guest
PostPosted: Sun Apr 28, 2002 12:38 pm    Post subject: Reply with quote
Worked -on this today...
http://home.attbi.com/~joedanka/porsche1/topend2.JPG
924Porsche1979JoeD.
[ This Message was edited by: Joes924 on 2002-06-05 06:05 ]
Joes924
Guest
PostPosted: Sat May 25, 2002 2:13 pm    Post subject: Reply with quote
Got the valves done ,cam arrived,put on the bigbore,first week of June Ill put it all together.
[ This Message was edited by: Joes924 on 2002-06-05 06:10 ]
coconutcowboy
Guest
PostPosted: Wed May 29, 2002 8:04 am    Post subject: Reply with quote
what is the difference in the audi 5000 tb and the 924 euro tb. Also what is the difference betwwen the euro head and the usa head. combustion chamber ? ports ? valves and related hardware ? cam ?
Is the intake different ? exhaust manifold ?
pleaze help.
Sean
porsche924 in georgia
[ This Message was edited by: coconutcowboy on 2002-05-29 08:06 ]
Joes924
Guest
PostPosted: Wed May 29, 2002 2:19 pm    Post subject: Reply with quote
First the heads the turbo head has better flow than a na head but isnt used because the na intake wont fit I guess you could use side draft carbs on it
2. the tb are the same for the euro and na
but the tb I have is from a rabbit its stamped [rabbit]audi-vw] its the one you want to run you,once installed put the idle screw in all the way retard your distributor a tad then start it & back out the idle screw a few C hairs [about ahalf a turn]
I couldnt get it to idle low enough ] so thats what I did.The diff. is the big bore requires you to port the intake it gives alot more flow.You can just take out the ring on the stock tbs. The cams are diff.
