Ulitmate weight Reduction! GUESS THE WEIGHT??
PORSCHEV
PostPosted: Thu May 24, 2007 6:18 am    Post subject: Ulitmate weight Reduction! GUESS THE WEIGHT?? Reply with quote
Ok..you can see alot of the stuff that came off the car here... amazing!
That big pile of junk laying beside the car is what was left of the carpets and interior.
The last shot is what it looked like under the carpets and under the under coating. BTW...you guys that want to strip it out. Fastest way is withan air chisel..took about 45 mins.
1978-#53 "D" track racer.
scottc
PostPosted: Thu May 24, 2007 6:42 am    Post subject: Reply with quote
Wow your daughter works quick!
I used a hammer and screw driver - poor mans air chisel when I had to get the undercoating / sound absorbant out. took a lot more than 45 minutes for a much smaller area.
PORSCHEV
PostPosted: Thu May 24, 2007 6:50 am    Post subject: Reply with quote
Yeah..I started that way. I wasn't too sure how solid the floor was. But once I got going I realized the floor was like new...out cam the air hammer....SO much faster!
Chrenan
PostPosted: Thu May 24, 2007 7:33 am    Post subject: Reply with quote
Hi Adam,
I have a favour to ask. I'm assuming this car had manual windows? Do you see the track on the bottom of the glass in the picture below (in the red box)? Does that come off the glass? Does it clip on or is it glued on?
I'm just thinking about my manual window conversion, and that track looks different to the one on the bottom of my power glass. I'm wondering if I need that version to go with my manual setup. Would you be willing to sell the tracks for left and right? Let me know.
Benino
PostPosted: Thu May 24, 2007 8:44 am    Post subject: Reply with quote
sorry I don't have the compolete picture. . .
but that first picture you posted looks like a ghetto thrashed version of this.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PORSCHEV
PostPosted: Thu May 24, 2007 9:41 am    Post subject: Reply with quote
The piece just clips/glues onto the bottom of the glass over a piece of rubber. You might have issues getting the ones you bought to fit your glass. I notice a difference in these manual windows from left to right due to the fact that one door had been swaped from another car. On the right door the window regulator goes onto the widow Via 2 rollers, where the left window uses a roller on one end and bolts to the bracket on the other.
Funny I was thinking of you when I took these apart and was wondering if your door shell has all the holes in the proper postions for the manual regulators... HOPEFULLY!
PORSCHEV
PostPosted: Thu May 24, 2007 9:45 am    Post subject: Reply with quote
I weighed the car tonight with the race tracks scales... Who ever said these cars are 2200 lbs stock is full of it! Anyway..take a guess at what it weighs now.
PostPosted: Thu May 24, 2007 9:46 am    Post subject: Reply with quote
1694 lbs.
PORSCHEV
PostPosted: Thu May 24, 2007 9:52 am    Post subject: Reply with quote
Thats what I expected it to come in at..but it was higher.
PostPosted: Thu May 24, 2007 9:59 am    Post subject: Reply with quote
2181 lbs
PORSCHEV
PostPosted: Thu May 24, 2007 10:04 am    Post subject: Reply with quote
The reflection from the lights makes it hard to read..but it is LF 424
RF 526 RR494 LR 375
I have the battery over the LR since I am trying to achieve a 55% left side weight (D shaped track) I still have to add in the roll cage, fuel cell and left fender. I am hoping to around 1950 without a driver.
Chrenan
PostPosted: Thu May 24, 2007 1:33 pm    Post subject: Reply with quote
Thanks Adam. Now that I'm at home, I looked again at my car, and the window and track at the bottom looks the same as yours in the picture, one short track, one long track (I also have a third track bolted to the inside of the door). All this "should" match up with the manual scissors I got which have 3 rollers each. We shall see. You may get a frantic PM this weekend asking if you've thrown anything out...
Tigger937
PostPosted: Thu May 24, 2007 2:05 pm    Post subject: Reply with quote
RF 526 RR494 LR 375
You could always throw a bag of helium in the trunk.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Mike924
PostPosted: Thu May 24, 2007 5:21 pm    Post subject: Reply with quote
So, what should the 'correct' stock weight be? My guesstimate would be around 2,500 lb.
1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org
PORSCHEV
PostPosted: Thu May 24, 2007 7:46 pm    Post subject: Reply with quote
I would say your right Mike ..must have been around the 2400/2500lb mark before I started.
Don't worry Chrenan..I won't be throwing anything that is good away, I have 2 cars of my own I need to keep in working order.
