Thermo time switch Replacement
19244jt
PostPosted: Fri Jul 27, 2007 8:48 am    Post subject: Thermo time switch Replacement Reply with quote
I have a cold/hot start problem that I have traced to a faulty thermo time switch. Haynes tells you how to test it but not where to find it or trcicks on how to remove it. I finally found it on the back of the motor on the bottom of the coolant flange but how do you get to it without removing the flange or motor etc.?? Any R & R tricks would be greatly appreciated.
Thanks, John
PostPosted: Fri Jul 27, 2007 10:47 am    Post subject: Reply with quote
I just recently did this. I already had the distributor and ign coil off and the aav out. Even then it was quite a bugger. I highly suggest ratcheting wrenches tho!
Its held on by 2 10mm bolts. then the whole housing comes off and you can remove the TTS. Its really not that bad, but I did have some creative hand contortions..
PostPosted: Fri Jul 27, 2007 11:54 am    Post subject: Reply with quote
If you have access to a pit or ramps it is much easier to get to from underneath. Failing that though, as Flosho suggests, remove the dizzy and then undo the 2 of 10mm bolts holding the aluminium adapter on. Its definitely worth the cost of a gasket.
Roger
19244jt
PostPosted: Sat Jul 28, 2007 1:31 am    Post subject: Thermo time switch Reply with quote
Sounds like I will be removing the flange then. Thanks guys!!
John
