924 Wheel Thread - Please Contribute
whywhywhy
PostPosted: Sat Aug 29, 2009 3:15 pm    Post subject: Reply with quote
15x7 Simmons V4's
Dreams of Porsche ownership ended in flames
9XX Girl!
PostPosted: Sun Sep 27, 2009 11:45 pm    Post subject: Reply with quote
All fixed now!
Compomotive CXN 16" x 10 on Back with 255/50/16
Compomotive CXN 16" x 8 on Front with 225/55/16
http://www.comp.co.uk/wheels/wheels.asp?range=CXN_0025
924 N/A 2 ltr 5 Speed (1984) UK
Adj Custom Front Struts & Beetle Rear Coilovers
951 Shell
911 Heated Seats
16” Split Rim Compomotive Race Alloys [255/50/16 Rear - 225/45/16 Front]
Audi 5000 Throttle Body, Dashboard Overlay, 195k Miles
thirdgenbird
PostPosted: Fri Oct 02, 2009 12:26 pm    Post subject: Reply with quote
Power Tryp wrote:
This is kinda funny, I thought by now you guys would have had all the wheels under the sun looked after.
Porsche 928 Club Sports
I'm looking into a set of these for track day wheels, anybody have issues with offset? is that why I haven't seen them?
Kinda look like a mix of D90 and Flatdish wheels.
im in the same boat. i want clubsports for track wheels, but i'm afraid that they will rub up front on a lowered car. my 6.5 in wide cayman wheels come very close with the required 7mm spacer.
here is what i THINK i know:
-without a spacer they will rub on the front coil (i have coillovers so i'm ok here)
(this comes from info on running 7in wide trash cans)
-with spacers they may rub on the fenders of a lowwered car
(this comes from my experience with my 6.5 in wide caymans that are close)
so if your lowered and dont need spacers your good and if your stock height spacers should make them work, anything else and ya may be boned.
like i said, this is speculation at this point. i will let you know more as a research...
edit: more info
alright my caymans are a 17x6.5 et 55
clubsports (7in wiide) are 16x7 et 60 (according to vw guys)
this means the clubsport would have 11mm less clearance on the back and ""stick out" 1mm more than what i have.
this should fine on a stock height car but a small spacer may be need for spring clearance.
on a lowered car you would probably be fine with a spacer if you stuck to a 205 tire. if you wanted to run a 215,, you probably would need to remove the spacer and you may rub your coils (unless you have coilovers)
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
PostPosted: Tue Oct 27, 2009 3:34 am    Post subject: Reply with quote
9XX Girl! wrote:
[size=18] All fixed now! :]
I am curious, the damage to that rim looks severe enough to have caused a-arm and strut damage. What all had to be repaired?
9XX Girl!
PostPosted: Tue Oct 27, 2009 4:21 am    Post subject: Reply with quote
Strut was fine, steering rack was fine, wing (fender) was fine, wishbone (A-arm) was the only thing other than the rim that was damaged. I don't have the wishbone any more but it tore and folded.
I hit a rock about 5" high at about 60mph
I know that some people like these custom wishbones
but they are too strong.
I like the pressed steel ones. They are the weakest link. If i had had one of these fancy ones fitted i would have caused structural damage for sure
951 Shell
911 Heated Seats
thirdgenbird
PostPosted: Tue Oct 27, 2009 5:05 am    Post subject: Reply with quote
steel ones also cost $20 and use low cost ball joints
9XX Girl!
PostPosted: Tue Oct 27, 2009 5:36 am    Post subject: Reply with quote
Yep, good init! I don't bother with changing ball joints and bushes, i just stick another wishbone on. cheap fix!
951 Shell
911 Heated Seats
Cédric
PostPosted: Tue Oct 27, 2009 6:44 am    Post subject: Reply with quote
15" 7" Cookie cutters, Et 23 if i remember correct. Track friendly camber (-2 or more) is recommended for the fit. Works really nice at the track with toyo r888 205/50 15. Rear spacer removed.
Just bought 16/7 flat dishs really cheap, i hope i wont have to big problems up front. Maybe some small spacer will fix that, that i will found out later this week
´79 924
´80 924 Turbo
Maybe924
PostPosted: Tue Oct 27, 2009 9:21 am    Post subject: Reply with quote
924s look great with Cookie Cutters. The factory should have offered a staggered 6X15 and 7X15 fitment as an option. While I really like the look of D90s they look a bit too modern for my taste.
Nice aggressive look Cedric.
1981 931 GT (CGT Intercooled)
1985 911 Targa Carrera (Sold)
Shurick
PostPosted: Thu Oct 29, 2009 8:14 pm    Post subject: Reply with quote
Does anybody use Boxter 16" rims (p/n 99636211200)?
[img]http://porschec.ru/attachment.php?attachmentid=702&stc=1&d=1251461662[/img]
I can put my hands on a set of this wheels, but I have no idea how they will look on a toofah.
WBR, Shurick
'79 931 -- non-ending project.
924S -- R.I.P.
PostPosted: Thu Oct 29, 2009 11:04 pm    Post subject: Reply with quote
[url]
[/url]
Shurick
PostPosted: Fri Oct 30, 2009 12:34 am    Post subject: Reply with quote
Thanks a lot! Looks nice...
WBR, Shurick
924S -- R.I.P.
moorepower
PostPosted: Wed Nov 04, 2009 11:43 am    Post subject: Reply with quote
Mille Miglia Cup I replicas. 7.5"X17", 53.2 offset with 205/50/17's all around. Looked good, but they weighed a ton.
Late offset 951 (944 turbo) phone dials. 7"X16", 52.3 offset with 205/55 front. 8"X16", 52.3 offset with 225/50 rear.
2002 Boxster wheels. 7"X17", 52.3 offset with 205/50 front. 8.5"X17", 55 offset with 255/40 rear (these rubbed a bit).
Late 944 wheels. 7"X15", 52.2 offset with 205/60 front. 7"X15", 52.3 offset with 215/60 rear.
931 Spiderwebs. 6"X15", 52.3 offset with 205/60 all around.
And finally, my current wheels. They need to be refinished, but I really like these. 928S4 flat dish. 7"X16", 65 offset with 205/55 front (with 6mm spacer). 8"X16", 52.3 offset with 225/50 rear.
I also got a great deal on these 996 wheels, 17"X7" and 17"X9", but I didn't have the guts to put them on the car.
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways, 931 header/valance panels
'81 924 Weissach with dual Weber carbs
Dankoneon81
PostPosted: Wed Nov 04, 2009 1:36 pm    Post subject: Reply with quote
yikes! super bright but I love them!
95 Neon gutted PnP MS2E turbo
94 Toyota sr5 the work horse
78 924 bone stock for now coming soon MS2E
PostPosted: Wed Nov 04, 2009 3:33 pm    Post subject: Reply with quote
Those pink twists are cool.
1981 Porsche 931 -- "Escalation of Commitment"
-Megasquirt 1v3.0 EFI/EDIS conversion, 250# springs, 17" turbo twists, 26.8/18 sways
Page 8 of 10
