Engine mount replacement
augidog
PostPosted: Sat Jan 20, 2007 2:28 am    Post subject: Engine mount replacement Reply with quote
http://www.924board.org/viewtopic.php?t=21273
1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work.
PostPosted: Sat Jan 20, 2007 3:16 am    Post subject: Reply with quote
how you like 'em so far? still good?
after reading up on these, I've budgeted for them in the wide body project. gotta get the engine put back together first, but these are on the shopping list.
tomcooper
PostPosted: Sat Jan 20, 2007 5:46 am    Post subject: Reply with quote
Dan,
You and I could almost do a group buy on these between the two of us. I need a set right now and another within the next six months. E-mail me and let's see what we can get going.
Tom
Casper and Big Red, both 1980 NA
Black Bart, 1990 944 S2 Cab
D Hook
PostPosted: Sat Jan 20, 2007 11:17 pm    Post subject: Reply with quote
I might be in for a set of those, also. Last time we had mine in the air, the passenger side mount was looking tired.
Need five or more sets for the price break, as I understand it.
'80 924 n/a SOLD
PostPosted: Sun Jan 21, 2007 12:04 am    Post subject: Reply with quote
Tom Cooper = 2
Ideola = 1
D Hook = 1(?)
Only need one more...
PostPosted: Sun Jan 21, 2007 12:08 am    Post subject: Reply with quote
errrr....one thing I forgot about, and not sure if this makes a difference...I need mounts for my 931...
augidog
PostPosted: Sun Jan 21, 2007 12:42 am    Post subject: Reply with quote
You can just buy direct and get just 1 if you need to. Same price as OEM.
They are discounted already and lower than the dealer prices.
Group buys would save about an additional $30.00 on the set and the shipping will be combined.
I needed mine right away so could not wait.
PostPosted: Sun Jan 21, 2007 1:07 am    Post subject: Reply with quote
I don't believe they're any different...
tomcooper
PostPosted: Sun Jan 21, 2007 1:16 am    Post subject: Reply with quote
Dan,
I agree with Vaughn, but I am going down to Springfield this morning and will check with Jim on what his looked like. If you need two, we have the group buy. Anyone else want to get in. I have not heard back from John in the UK to confirm the price, however, the exhchange rate yesterday afternoon was 1.975 dollars per pound.
Tom
PostPosted: Sun Jan 21, 2007 3:10 am    Post subject: Reply with quote
I'm in for two.
PostPosted: Sun Jan 21, 2007 5:41 am    Post subject: Reply with quote
Clarification. I need one set for my 931 wide body. For some reason I had it in my head that the mounts were different than the NA...my mistake. With Rasta, we should have enough for the group buy...
D Hook
PostPosted: Sun Jan 21, 2007 7:49 am    Post subject: Reply with quote
"We would consider 5 sets and above for a group buy at £100/pair."
I'm in for a set but probably only NEED one, if someone else would like to split a set with me.
They're identical, right? And will fit either side for either 924 or 931?
'80 924 n/a SOLD
Ozzie
PostPosted: Sun Jan 21, 2007 7:52 am    Post subject: Reply with quote
Not identical but could be made to fit.
The LHS is all rubber whereas the exhaust side is metal spring.
Its AUTO and its BLACK
Montego Black on black/red
D Hook
PostPosted: Sun Jan 21, 2007 10:13 am    Post subject: Reply with quote
Right. By identical, I meant the mountings are the same. The points where they make contact w/the motor and frame.
The one I want to replace is the one on the passenger side; the one w/the spring.
Thanks Ozzie.
'80 924 n/a SOLD
Ozzie
PostPosted: Sun Jan 21, 2007 12:20 pm    Post subject: Reply with quote
The width of the spacing between the bolts is different but by elongating the hole they should fit either side.
I forget which is smaller but its only about 6mm diffierence.
