how to check the warm up regulator
steve
PostPosted: Fri Aug 24, 2001 6:28 am    Post subject: Reply with quote
does anyone know how to check the warm up regulator to see if it works? i've had a starting problem ever since i rebuilt the engine in my 1977 924na. i've replaced the injectors, the cold start valve and the fuel pump the only thing left that i know of is the warm up regulator but before i replace it i want to make sure its bad.
if it is bad does anyone know where i can get a new one?
thanks for the help.
steve
PostPosted: Fri Aug 24, 2001 8:45 am    Post subject: Reply with quote
As it says on the FAQ (or at least the tech section), get the fuel pressure gauge and run through the tests in the Haynes manual...
