Rear Brakes
bass gt
PostPosted: Sat Jan 06, 2007 10:45 am    Post subject: Rear Brakes Reply with quote
Hi Guy's,
Another seemingly strange Q, but here goes!!.
Do any of you know the piston diameter of the 931 rear brakes??
Many Thanks,
Steve
-nick
PostPosted: Sat Jan 06, 2007 11:09 am    Post subject: Reply with quote
54mm front and 36mm rear. I think that's from the tech/spec book.
1980 931S
1991 964 C4 Cabriolet
PostPosted: Sat Jan 06, 2007 12:43 pm    Post subject: Reply with quote
Yessir, the little book says 54mm-front, 36mm-rear for the 5-bolt, 4 wheel disc setup.
-And for the 4-bolt disc-front, drum-rear arrangement it's 48mm-front and 19.05mm-rear.
bass gt
PostPosted: Sat Jan 06, 2007 1:42 pm    Post subject: Reply with quote
Thanks guy's,
In case you are wondering, i am fitting a Tilton pedal box into the car, and need to calc what size master cylinders i will need.
Steve
bass gt
PostPosted: Sun Jan 07, 2007 5:18 pm    Post subject: Reply with quote
Sorry,
Are the rears single piston, or one piston each side??
Thanks
sequential
PostPosted: Sun Jan 07, 2007 5:24 pm    Post subject: Reply with quote
bass gt wrote:
Thanks guy's,
Steve
NOT TO WORRY , YOU are going to purchase a few master cylinders, before you are happy, even after measuring everything 10 times ,
bass gt
PostPosted: Sun Jan 07, 2007 5:44 pm    Post subject: Reply with quote
Hi Wayne,
Tilton reckon that if i give them the specs of the car, they can size it all up in one shot. Well thats the theory anyway. Will be nice to get rid of the servo assistance anyway...
Steve
Raceboy
PostPosted: Sun Jan 07, 2007 7:06 pm    Post subject: Reply with quote
If you need more piston diam. at the rears, you can use 4bolt front pistons with barrels, they fit.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
bass gt
PostPosted: Sun Jan 07, 2007 7:16 pm    Post subject: Reply with quote
Raceboy.
Do you mean the front calipers from a 4 lug car?
Raceboy
PostPosted: Sun Jan 07, 2007 9:24 pm    Post subject: Reply with quote
bass gt wrote:
Raceboy.
No, not complete calipers, because they have smaller space for pads+rotor (remember, vented rotor on 5lug vs solid on 4lug). Just the piston with the barrel or cylinder, whatever you call it.
'67 911 2.4S hotrod
'84 928 S
'91 944 S2, sold
ic932
PostPosted: Sun Jan 07, 2007 11:07 pm    Post subject: Reply with quote
if i remember correctly you are using willwood 4 pots up front? maybe 951 brembo's and 951 (86') rear discs would work well with the wilwood front calipers?
it just so happens i have brand new 951 discs and mint 968 4 pot brembo rear caliper's for sale ....hmmmm
bass gt
PostPosted: Mon Jan 08, 2007 1:51 am    Post subject: Reply with quote
Hmmm indeed . Drop me a pm with your thoughts......
sequential
PostPosted: Mon Jan 08, 2007 3:43 am    Post subject: Reply with quote
bass gt wrote:
Hi Wayne,
Steve
HELLO Steve,
Yeah they will be able give you a master based ,based on the information , but it is very rare to get it right in one shot. as pedal feel is dependant on your driving style...
bass gt
PostPosted: Mon Jan 08, 2007 6:25 am    Post subject: Reply with quote
sequential wrote:
bass gt wrote:
Hi Wayne,
Steve
HELLO Steve,
That'll be crap then...
sequential
PostPosted: Mon Jan 08, 2007 6:58 am    Post subject: Reply with quote
bass gt wrote:
sequential wrote:
bass gt wrote:
Hi Wayne,
Steve
HELLO Steve,
Yeah,
Usually it takes 3 attempts at sizing for most to be happy with master cylinder feel and performance.
