Just shed 7.5 lbs of rotating mass
-nick
PostPosted: Mon Nov 20, 2006 4:16 pm    Post subject: Just shed 7.5 lbs of rotating mass Reply with quote
This worked out quite nicely. I started looking for a 911 pressure plate to get some extra clamping force on the clutch. Turns out that Sachs made cast iron plates as part of a stock clutch kit and also a "sport" kit that includes an alloy plate. The alloy plate weighs a whopping 7.5 lbs less than our stock 931 cast iron plates!
All I could dig up on clamping pressure numbers are these-
7200-7900N for stock 931 pressure plate
7800-8500N for stock 911 pressure plate
There is _definitely_ more pressure at the pedal. I might look into reinforcing the firewall to avoid any possibilities of fatiguing the metal. We'll see how tiring it gets to operate too...
The only trick is that replacing the throw out bearing is much more of a pain in the a$$. Maybe there are some tricks on the 911 board.
Anyway, you can use the pressure plate from any of the 915 transaxle cars - 911SC, 80's 911 Carrera. I think the years are '72-'86.
ps - I've got an extra good 931 pressure plate if anyone wants it (not the rusty one in the pics!).
1980 931S
1991 964 C4 Cabriolet
bass gt
PostPosted: Mon Nov 20, 2006 5:15 pm    Post subject: Reply with quote
Nick,
I discovered the same thing a while ago. I bought an old 911 pressure plate off ebay, and not only did it fit right up, but it seemed a lot lighter.
What friction plate are you using??
This whole clutch issue is starting to bake my noodle, what with the different S1 & S2 clutches, blah blah. I am looking for a proper race spec clutch, and as i am in the process of having a 2.2 litre engine built, i am on the hunt for a decent clutch. The other option is to have a friction plate custom made
Or is the Ford Bronco friction plate you guy's use over there much stronger than the OE Sach unit??
Steve
-nick
PostPosted: Wed Nov 22, 2006 3:16 am    Post subject: Reply with quote
I was curious what the 944/951 spring centered clutches look like? The spline is obviously the right size. Maybe they're not a 225mm disk? There are lots of disk options floating around for them.
I'm using the stock OEM clutch disk. I felt like it could use a little more "grab" before, hopefully the new pressure plate will help.
For what it's worth, there are a lot of bad stories floating around about the Spec clutch disks. A handful of newer Corvette owners have had there cars practically sawed in half when their Spec disks blew. I read a couple of the stories, and these weren't high mileage abused disks either. Spec's response was 'sorry about your luck' in all the cases. Apparently the 'vettes are made such that the disk won't saw the driver's legs off if it lets go. Something I wouldn't want to chance!
I'm not sure about the other brands out there, Centerforce, etc. Sachs seems to at least have a good reputation for holding together; as far as I know at least.
1980 931S
Chrenan
PostPosted: Wed Nov 22, 2006 5:33 am    Post subject: Reply with quote
Nick, I'm assuming this upgrade wouldn't work on a 924?
bass gt
PostPosted: Mon Nov 27, 2006 11:22 pm    Post subject: Reply with quote
Nick,
Just to give you, and those that may be interested, an update. I have ordered the same pressure plate as you, the Sachs Sport 911 clutch kit, and found that AP racing, a rather well known brand, make a cerametallic, 6 paddle friction plate spcifically for our cars. Now this may be a tad strong and aggressive for steet use, as it is a specific race clutch, however Helix Autosport make a full range for the S2 and GT models, from street use to group N. Happy days. This is going into my new engine, which i am currently seccing up. I will give you a taster once the list is complete.
Regards,
Steve
Raceboy
PostPosted: Tue Nov 28, 2006 12:57 am    Post subject: Reply with quote
Bit offtopic, but Steve where are you sourcing main and rod bearings? I assume you're using .25mm oversize ones?
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
bass gt
PostPosted: Tue Nov 28, 2006 1:18 am    Post subject: Reply with quote
Raceboy,
I beleive we are fitting VW Golf items. The rods i thiink will be Steel Golf items, with custom pistons to suit. I'm guessing here, but if golf rods are going in, golf bearings must be ok. Crank may ned a macine to size up ok, but we shall see.
BTW, going for 7 mm valve stems! Custom build. Difference in restriction is amazing.
-nick
PostPosted: Tue Nov 28, 2006 2:51 pm    Post subject: Reply with quote
Chrenan - no luck on the 924na. Although, I don't remember the na plates being too heavy to begin with. The 931 plate is a monster!
Steve - your latest build sounds great! I believe that the Golf rods use a smaller diameter on the big end. Turning the crank down a mm or so definitely won't hurt that cast iron diesel beast. Did you consider looking into having the crank offset ground to gain some displacement? Or are you restricted within your class? I'm looking forward to hearing about the results.
1980 931S
JSMotors
PostPosted: Mon Dec 11, 2006 1:48 pm    Post subject: Reply with quote
Nick-
Why wouldn't this upgrade work on a 924 NA? Any way to make it fit? Are you only using the pressure plate or a full assembly?
endwrench
PostPosted: Mon Dec 11, 2006 3:40 pm    Post subject: Reply with quote
The 931 flywheel is stepped. I believe (someone please correct me if I am wrong) that the pressure plate mounting surface is higher than the friction surface of the clutch.
Also, the 924 torque tube is designed for a 24 tooth x 13\16" x 8 1\2" disc and the 931 is 23 tooth x 1 1\16" x 8 13\16". I don't know of any other disc that would fit the 931 pressure plate with the 924 torgue tube. Ofcoarse this can be fixed by changing to the 931 tube and tranny if your willing to go that far.
I've been researching this subject for quite a while as my clutch is starting to show some weekness at my current boost level and I would like to turn it up a little more in the future. Too much torque
Todd
-nick
PostPosted: Tue Dec 12, 2006 5:08 am    Post subject: Reply with quote
I think the biggest difference between the 931 and n/a plates are that the 931 is a pull-type (TO bearing moves away from engine to disengage clutch) and the n/a is a push-type (TO bearings moves toward engine).
The stock 931 plate is a massive piece of iron! I don't think the n/a plate is very heavy to begin with.
The 931 flywheel also does have a small "step" in it - but it's just a raised portion around on the outside of the pressure plate. I think it's just there to help center the pressure plate. You could probably shave it off without any ill effect. The mounting surface of the pressure plate and the clutch surface are at the same level on the 931 flywheel.
Todd - good luck resolving your clutch trouble! I don't know of any easy ways to get a bigger disk in there.
Here are a couple pics, I don't think I have a shot of the surface side of the flywheel...
1980 931S
endwrench
PostPosted: Tue Dec 12, 2006 10:51 am    Post subject: Reply with quote
Interesting. I've replaced hundreds of clutches and I have never seen one the "pulls" the throwout bearing! Nor have I seen a ring gear mounted to one. Crazy Germans!
Todd
-nick
PostPosted: Fri Jan 12, 2007 3:06 am    Post subject: Reply with quote
!Achtung!
If you look _really_ closely in the pic of the two plates, you'll notice a raised rivet just clockwise of one of the bolt holes on the alloy plate. On the stock plate, the raised rivet is just counter-clockwise of the bolt holes. In fact, there are two rivets next to each other on the stock plate, but one is sunk.
The 931 ring gear has a cut-out for the raised rivet - which is in the wrong place if you use the alloy plate! When you bolt the ring gear down it will deform and not sit flush, which you won't notice until you try and shift gears and find the clutch dragging...
I drilled new cutouts into the ring gear and now the gear sits perfectly flush against the pressure plate. I warped the gear that I first bolted on without the cutouts, luckily I had an extra one to drill.
The 911 ring gear (for the 915 trans) should bolt right up and be correct. Unfortunately, I didn't have one lying around.
Shifting should be much improved - aka, I should be able to select 1st and reverse.
1980 931S
arx
PostPosted: Fri Jan 12, 2007 5:56 pm    Post subject: Reply with quote
Thats a weirdest clutch I've ever seen
Raceboy
PostPosted: Fri Jan 12, 2007 7:09 pm    Post subject: Reply with quote
Argo, sellist tüüpi sidurid on nii 931'l kui 944'l kui teistel Porschedel.
'67 911 2.4S hotrod
'84 928 S
'91 944 S2, sold
