bass gt
Posted: Mon May 21, 2007 7:48 am Post subject: |
Mac,
What turbo did you go for?? Would be interested to see what the response is like, ie spool up point ect.
Steve |
macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Mon May 21, 2007 9:41 am Post subject: |
Garret GT28R, i'll let you know what the response is like in a few weeks. _________________ 1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways |
Joined: 01 Jul 2004 Posts: 3155 Location: Eau Claire, Wisconsin
Posted: Mon May 21, 2007 9:52 am Post subject: |
What size lines and AN fittings did you use for the fuel lines going to and from the fuel rail/fpr? _________________ [This Space For Rent] |
bass gt
Posted: Mon May 21, 2007 10:15 am Post subject: |
Mac,
Thanks. Thats the unit i'm thinking of using. what trim?? |
macBdog
Posted: Mon May 21, 2007 10:47 am Post subject: |
Its -4 lines and fittings from the rail to the FPR and back to the return. -6 Lines from the fuel filter to the rail. The fuel filter and return line needed a little black bosch adapter to join up.
The turbo ive got is standard equipment for a nissan GTR skyline so the compressor trim is 60 and the turbine is 76. _________________ 1979 931 with a 350 chev
1973 911E with EFI
macBdog
Posted: Tue Jun 26, 2007 11:42 pm Post subject: |
Well it looks like I will start tuning this weekend. I have had many hassles trying to get my fuel rail to seal properly. I even built a second rail that worked with hose and clamps that was a total failure. In the end I got some holes milled in a length of fuel rail extrusion and that does the job beautifully. On with the pics!
First the fuel rail graveyard:
And now the new unit in place and leak free:
Also managed to create the worlds smallest air filter in order to clear the sway bar:
1973 911E with EFI
Posted: Wed Jun 27, 2007 8:03 am Post subject: |
macBdog wrote: | Also managed to create the worlds smallest air filter in order to clear the sway bar: |
Don't forget "least effective!" _________________ Toofah King Bad
macBdog
Posted: Wed Jun 27, 2007 11:34 am Post subject: |
Rasta Monsta wrote: | Don't forget "least effective!" |
Also "least restrictive". It's just a stop gap for the moment till I work out how to drop the sway bar a few inches to run a proper air filter. Any other ideas? the damn thing is right in front of the turbo inlet! _________________ 1979 931 with a 350 chev
1973 911E with EFI
Posted: Wed Jun 27, 2007 7:09 pm Post subject: |
why not just route a pipe to the front of the car ? _________________ https://www.the924.com |
Posted: Wed Jun 27, 2007 11:23 pm Post subject: |
Why not just look at the photo, man?
Martijnus
Posted: Thu Jun 28, 2007 2:24 am Post subject: |
weird vbelt btw...
I'd find a solution for that air filter... no matter how...
especially because of the turbo... or are they sh*t-resistant? _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Thu Jun 28, 2007 2:28 am Post subject: |
Martijnus wrote: | weird vbelt btw... |
I'll second that. . .looks inside-out.
Could you work on the turbo inlet, maybe cut some off at an angle and attach an elbow there? I'm afraid that piece of foam will get sucked right in! _________________ Toofah King Bad
kogaisrude
Posted: Thu Jun 28, 2007 12:50 pm Post subject: |
thats not an unusual v-belt anyway nice work i like it _________________ 1977 924 stock |
Posted: Fri Jun 29, 2007 4:43 am Post subject: |
Perhaps flipping the sway bar upside down and spacing the mounts down a little might get you enough clearance? |
Posted: Fri Jun 29, 2007 5:40 pm Post subject: |
Cut and re-weld after the inner mounts??
leadfoot _________________ 1981 ROW 924 Turbo -
