macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Mon Nov 13, 2006 3:57 pm Post subject: A chilling vision of things to come |
Just starting the major work for the EFI + Garrett conversion. Check it out:
Starting on the fuel rail and new injectors in place. They are Bosch 480cc units.
Mock up of the new manifold and turbo compared to the old one above. The KKK has completely seized and can only be spun with a ratchet attached.
_________________ 1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways |
Khal
Joined: 26 Sep 2003 Posts: 4869 Location: Sunny and lovely interior BC, Canada
Posted: Mon Nov 13, 2006 5:06 pm Post subject: |
I just read the Cars and Parts Wanted/For Sale forum and thought, "What the..?"
Now it all makes sense. |
Joined: 29 Jul 2001 Posts: 8806 Location: Royal Oak, MI, USA
Posted: Tue Nov 14, 2006 12:36 am Post subject: |
I wouldn't be surprised if your old turbo is coked up in the exhaust section... _________________ Vaughan Scott
endwrench
Posted: Tue Nov 14, 2006 4:12 am Post subject: |
Looking nice. How much HP do you plan to make? I ask because I did a little logging on mine this weekend and found I am seeing 80%+ duty cycle already at 6200rpm and 44lb injectors. I can't be pushing more than 180HP. Rack it up to supercharger inefficiancy? Maybe more HP than I think? Seems odd to me.
Is that 1 inch square tubing for the fuel rail!? Monster!
Kenodog
Posted: Wed Nov 15, 2006 10:59 am Post subject: |
I can't believe Khal hasn't slammed it yet.
Personally I think it looks like a great beginning. Which Garrett are you using ? and did you make the fuel rail yourself ? (could you tell me the pitch between the injectors so I don't have to measure mine.) _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Min
Posted: Wed Nov 15, 2006 1:45 pm Post subject: |
Kenodog wrote: | I can't believe Khal hasn't slammed it yet. |
Be nice, it doesn't look anything like that monstrosity. To me, it looks like he's building a log manifold in fact. Judging from the direction of those weld el's. That right macbdog?
Looks awesome.
Kenodog
Posted: Wed Nov 15, 2006 2:41 pm Post subject: |
Min I wasn't slagging the work, I was just poking fun of khal.I'm allowed to,he still owes me a Coke.
MacBdog is making exactly what I (eventually) plan on making.A log style manifold with a Garrett spinner.This has to be the easiest way to fabricate a reliable,long lasting manifold.Keep the pics comin' McB _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Vince Ponz
Posted: Fri Nov 17, 2006 8:05 am Post subject: |
I wish you guys were near me. I would love to help working on these projects. I stuck with a US car guy building a 33 Plymouth 4 door rocket, a coffin car ala the Munsters and a 29 Ford pickup. With the coffin car we made the NY Daily News, were on ABC and CBS during Halloween. I will try to get the coffin car on this site. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
macBdog
Posted: Fri Nov 17, 2006 11:07 am Post subject: |
Min wrote: | Judging from the direction of those weld el's. That right macbdog? |
Yup thats right, I'm making a log manifold for a Garrett GT2871R with a .60 trim. I mucked around with a few other manifold configurations but there just isnt the space for someone with basic fabrication skills. After inspecting the inside of the stock manifold, I reckon the large steam pipe elbows will flow pretty good. The curves are smooth and the bore is plenty large. Pulses from the #4 runner should keep everything moving in the right direction. The #1 runner is pitched 45 degrees clockwise to position the turbo in the same spot as the KKK.
Yes the fuel rail is 1 inch square tube, I wanted to give myself plenty of room when welding the injector bungs. The bungs are made from 13.6mm ID steel tube so it should squash the orings enough not to leak.
Kenodog, the injector pitch was somewhere around 93.5mm. 1&2 measured 93 and 2&3 measured 94. There is play in both the stock injectors and the new inserts so it should be fine. I am planning on using the intake manifold bolts and rocker cover studs as mounting points to hold the rail down.
My target is 200HP at the treads.
924RACR: you are right. There is also enough play in the shaft that the compressor wheel has been turned to aluminium dust - when I take it apart fully I will show pics. Thank god my intercooler acted as a filter and caught all the shards. _________________ 1979 931 with a 350 chev
1973 911E with EFI
Raceboy
Posted: Fri Nov 17, 2006 4:04 pm Post subject: |
MacBog, GT2860R is way more capable than 200@ the wheels In fact, couple of days ago we installed this turbo to the Audi A4 1.8T quattro and with standalone it made something like 270-280 flywheel hp WG spring set to minimum pressure (.7-.8 bars or so).
Good luck with the project! _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Fri Nov 17, 2006 4:27 pm Post subject: |
Kenodog wrote: | I was just poking fun of khal.I'm allowed to,he still owes me a Coke. |
yeah he owes me some coke too
damn him _________________ Toofah King Bad
Kenodog
Posted: Sat Nov 18, 2006 12:22 am Post subject: |
Rasta Monsta wrote: | Kenodog wrote: | I was just poking fun of khal.I'm allowed to,he still owes me a Coke. |
damn him |
I'm not gonna touch that one. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Min
Posted: Sat Nov 18, 2006 3:19 am Post subject: |
whats the inner diameter of those weld el's macbdog?
-nick
Posted: Sat Nov 18, 2006 4:33 am Post subject: |
Ugh, I have Garrett GT envy. Some 911 folks have reported that you can hear the turbo spinning down for almost a minute even after shutting the ignition off. Cool
Slightly OT - has anyone made a ball bearing cartidge for KKK? Or is Garrett's really that special? _________________ 1980 931S
1991 964 C4 Cabriolet |
Kenodog
Posted: Sat Nov 18, 2006 10:26 am Post subject: |
It's not just the BB cartridge that's cool but also the 360 degree oil seal that keeps it from leaking over time.
This post has me stoked again about doing my manifold.Hey McB when you get it finished can you post a small video clip so we can hear it,that would be uber cool. _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
