Anyone run the 931 motor, out of the vehicle ?
OutOfTheBox
PostPosted: Thu Aug 31, 2006 3:04 am    Post subject: Anyone run the 931 motor, out of the vehicle ? Reply with quote
I want to rebuild my motor, and then run it out of the vehicle.
1. Anyone done this ?
2. Whats the most you can leave on the motor, and still manage to drop it back in the vehicle ?
3. Will the clutch plate run out of alignment, without the drive shaft holding it centre.
Anyone got a spare torque tube and shaft, they could cut the first couple of feet off and mail to me ? I was hoping to be able to weld up a metal encased concrete flywheel running in a tank of oil, to make a dyno.
JB 924
PostPosted: Thu Aug 31, 2006 10:53 am    Post subject: Re: Anyone run the 931 motor, out of the vehicle ? Reply with quote
Am I the only one amazed by what you always come up with?
PostPosted: Thu Aug 31, 2006 3:05 pm    Post subject: Reply with quote
PostPosted: Thu Aug 31, 2006 3:07 pm    Post subject: Reply with quote
make sure you have enough exhaust attached so the engine doesn't draw cold air into the turbo on off-throttle (ka-rack)
OutOfTheBox
PostPosted: Thu Aug 31, 2006 6:33 pm    Post subject: Reply with quote
You haven't seen my last project, before my 931;)
A Super Critical Reactor !
A pressure vessel and pump capable of squashing things upto a pressure of 800 Bar, thats 12,000 psi. Now thats what I call BOOST!
At pressures above 500 Bar, certain materials become super critical, and behave as both liquids/gases/solids, at the same time.
Looks like mercury, or something shot from the hubble telescope.
The pump came from the Toyota factory, I think they used it for the presses that squash the car panels.
It's powered by a 10KW 3 phase motor.
Ever wonder what happens at the murkiest depths of our oceans, come see me
PostPosted: Thu Aug 31, 2006 7:44 pm    Post subject: Reply with quote
i just might visit you...with a few pieces of barbeque carbon in my pockets and some wishes
there is a engine dyno ~50Km from my place...why do you want your engine dynoed ? cant you dyno your car ? or you want to find out exactly how much power you loose trough the transmision ?
OutOfTheBox
PostPosted: Fri Sep 01, 2006 2:48 am    Post subject: Reply with quote
I want to quickly see the effects of engine mods, without having to stick the motor back in the car
Tigger937
PostPosted: Fri Sep 01, 2006 10:16 am    Post subject: Reply with quote
.............and I thought it was nuclear. Gee, I'm disappointed.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Khal
PostPosted: Sat Sep 02, 2006 4:30 am    Post subject: Reply with quote
Joakim did it...
'80 924 Turbo
OutOfTheBox
PostPosted: Sat Sep 02, 2006 4:41 am    Post subject: Reply with quote
great stuff !!! is he a board member ?
Khal
PostPosted: Sat Sep 02, 2006 4:58 am    Post subject: Reply with quote
Impressive, no?
He was a 'board member. Don't know if he's still around..?
'80 924 Turbo
OutOfTheBox
PostPosted: Sat Sep 02, 2006 5:14 am    Post subject: Reply with quote
Yeah thats impressive !
"was" ???
you guys didn't tell him about putting smelling salts in his motor for sticking rings, did you
D Hook
PostPosted: Sat Sep 02, 2006 8:38 am    Post subject: Reply with quote
I believe he was killed in a freak pickle plant explosion. Something to do with concrete and oil and dynos. Don't recall the details........
'80 924 n/a SOLD
bass gt
PostPosted: Sat Sep 02, 2006 8:46 am    Post subject: Reply with quote
Khal,
I'm in contact with him. The motor however went on a proper engine dyno, not a Heath Robinson contraption consisting of an oil drum, two rolls of duct tape, eight litres of oil and a super critical reactor...
Last i heard, he was up near the 400BHP mark, at the flywheel.
OutOfTheBox
PostPosted: Sat Sep 02, 2006 9:16 am    Post subject: Reply with quote
Next time you chat ask him how to prepare the cylinders properly so you dont need to go pouring your mums vim in there, to seat the rings properly.
NO MATTER WHAT I MAKE IT OUT OF, ITS NEVER GOING TO LOOK SO $$$ $$$$ UGLY AS YOUR TANGERINE PIMP MOBILE:)
