solid tranny mounts
Goto page Previous  1, 2
Vince Ponz
PostPosted: Wed Aug 23, 2006 11:32 pm    Post subject: Reply with quote
Okay guys........be sure to check the motor mounts regularly. If a bolt breaks you may have to remove the engine to grind it out. Ask me how I know.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Thu Aug 24, 2006 12:11 am    Post subject: Reply with quote
Solid motor mounts WILL rip the engine mounting points off the chassis unless you reinforce the areas
3 928s,
Adie
PostPosted: Thu Aug 24, 2006 5:46 am    Post subject: Reply with quote
At first I thought that will rip off but lets think about this, the engine can no longer twist but should be able to move up and down slightly(the mount bolt being the axis). If you put a torque strap on hte engine like a lot of racers do you would also stop the engine from making rotational force reducing the stress on that force on the rear solid mounts, while still having the dampening ability of the original mounts, kind of like a 1/2 watts linkage on hte engine, if you were to do this I think you would have a set up that could last a LONG time.just need a couple of rose joints and mounts and your away. I thought about it for the race car once but I have a motorplate on my engine so it would have been a wasted exersize but on a stock setup it can be made to work with the existing configuration. I think the torque of the engine will be the undoing of the mounts, if it's not controlled.
924 zero cylinder race car,
PostPosted: Thu Aug 24, 2006 9:30 am    Post subject: Reply with quote
the ideea to prevent the motor from rotating might save the tranny with solid mounts...but dont forget about vibration.
anyway...
the force developed by the engine when rotating or tranlsating on vertical axis WILL EXIST and WILL AFFECT whatever the engine is strapped to....the forces will still be there...only thing different is that they will affect some other part of the body and the engine might not rotate so much...
simsport
PostPosted: Thu Aug 24, 2006 9:51 am    Post subject: Cracks Reply with quote
I did have cracks on the inside of the front bulkhead adjacent to the left engine mount bracket. We put these down to the very hard Vibratechnics mounts. However in all honesty for a comp car, so what?
For a road car they offer a softer grade with less risk of cracks.
The worst possible is having one or other end of the car (engine or gearbox) solidly mounted and the other not.
You have two heavy items at the end of a long lever, if both are fixed ok, if one is and the other not all the forces are increased on the end that is fixed and for that matter along the full length of the torque tube.
Cheers
Simon
Blown is always best!
CBass
PostPosted: Thu Aug 24, 2006 11:02 am    Post subject: Re: Cracks Reply with quote
Cheers
Simon
While that sounds terrifying, I'm running a naturally aspirated engine making not all that much power and I'm quite gentle with my car. Fast, but smooth and every action is properly rev matched and my load transitions are very smooth.
The alternative is definately having a transmission failure. I'm not much for that option. Hey Vince, how's about that mount?
CBass
PostPosted: Sat Sep 02, 2006 3:28 am    Post subject: Reply with quote
Update, mounts are holding up fine and no sign of any damage or fatigue. Not yet at least.
PostPosted: Sat Sep 02, 2006 4:01 am    Post subject: Reply with quote
Solid motor mounts + solid tranny mount = my dream...
I figure with a flex pipe in the downpipe and wastegate, and there shouldn't be any problelm in the exhaust.
Kenodog
PostPosted: Sun Sep 03, 2006 8:47 am    Post subject: Reply with quote
Yeah but what no one has mentioned is the fact that once the engine and tranny have solid mounts,making them almost a single unit,there is still going to be a fair amount of torsional stress on both sets from flex in the body.This will make hard cornering almost as stressful as hard shifting,maybe worse if you really like to pull the G's.
jmho
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
2016 DR650
2019 KTM 790 Adventure
CBass
PostPosted: Sun Sep 03, 2006 4:29 pm    Post subject: Reply with quote
Well interesting development. I fly out for a camp job tomorrow and will be returning with enough coin to do an engine swap. Plans so far call for a 3.0 16v 968 engine and 6 speed, solid mounted to a custom aluminum front crossmember.
This is going to be nutty. So off I go to spend the next two months on a mountainside in northwestern British Columbia, drilling holes in the ground.
PostPosted: Sun Sep 03, 2006 7:31 pm    Post subject: Reply with quote
hey ! this i never tought about....making a custom crossmember for the 924 to put a 944/968 engine in it....wow...nice ideea !
JB 924
PostPosted: Mon Sep 04, 2006 12:02 am    Post subject: Reply with quote
Good luck with that engine swap, CBass. Hope to see some pics!
JB 924
PostPosted: Mon Sep 04, 2006 12:03 am    Post subject: Reply with quote
Page 2 of 2
