Sudden shudder in when leaving the line.
CBass
PostPosted: Tue Jul 25, 2006 3:15 pm    Post subject: Sudden shudder in when leaving the line. Reply with quote
My car recently started shuddering heavily when leaving a stop. I played around on a rural road and found that if I use certain combinations of gas and clutch it doesn't seem to be an issue, but at other time's it's horrible!
Searched similar threads
http://www.924board.org/viewtopic.php?t=15742&highlight=vibration
http://www.924board.org/viewtopic.php?t=12346&highlight=clutch+judder
No real definitive answer though.. I did recently adjust my ignition timing, but otherwise that's about it.
Anyone have any recent experience?
Tigger937
PostPosted: Tue Jul 25, 2006 3:38 pm    Post subject: Reply with quote
Had a similar experience about a year ago. I can remember a few times accelerating from a stop and noticing the RPM's revving higher than normal accompanied by severe lack of acceleration. Lasted a short time, then disappeared after a few hard accelerations. Best I could figure was that it appeared to be disc slippage in the clutch possibly due to oil, grease or some other substance leaking on the disc surface. The car had sat for quite a while (several months) which may have contributed to the problem.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
CBass
PostPosted: Tue Jul 25, 2006 4:03 pm    Post subject: Reply with quote
No clutch slippage under driving, it doesn't do it if I start from a low rpm with gradual clutch slippage. I gave it a few goes with some oomph and it felt awful, looks like it's coming from the rear end for sure. Crawling under in 5 minutes. *cringe* [/code]
CBass
PostPosted: Tue Jul 25, 2006 4:39 pm    Post subject: Reply with quote
Found the cause. Tranny mounts were twisted. My fault, I double checked the tightness on everything a few days ago when I noticed my boots were going on teh one axle. Looks like I tightened the nut enough that it spun the mount slightly!
So the transmission was being loaded by the side, and the mounts couldn't resist the twisting as much. So much fun! Car drives much better now that I fixed it.
Tigger937
PostPosted: Wed Jul 26, 2006 12:32 pm    Post subject: Reply with quote
Nice work! Always like to hear happy endings that don't cost anything.
1981 931 (Concours)
