2nd plug in oil pan above the drain plug - what size?
Chrenan
PostPosted: Fri Jun 16, 2006 8:01 am    Post subject: 2nd plug in oil pan above the drain plug - what size? Reply with quote
Is the second smaller "other" oil drain hole, above the "real" oil drain hole M16x1.5?
I'm considering ditching my clock for an oil temperature gauge.
Gauge:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=VDO%2D310106&N=115&autoview=sku
Sender:
http://store.summitracing.com/egnsearch.asp?Ntt=323056&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115
Chrenan
PostPosted: Tue Jul 25, 2006 2:49 am    Post subject: Reply with quote
Just bumping this to the top again to see if anyone knows off the top of their head. The parts catalogue is no help.
PostPosted: Tue Jul 25, 2006 4:46 am    Post subject: Reply with quote
Mine's definitely M14x1.5, but Ideola found his to be M16. Look here -
http://www.924board.org/viewtopic.php?t=14376&start=5
Chrenan
PostPosted: Tue Jul 25, 2006 5:23 am    Post subject: Reply with quote
Hmm, I'll have to investigate further I guess, strange that 2 people would get 2 different sizes, I though the oil pan was the same throughout 924 development.
Does anyone know what temperature the oil runs at in a 924? I've heard 180 F, but I amy be way off. I was going to get the 150-300 degrees F gauge with the 300 F sender. Make sense?
Meneer aard
PostPosted: Tue Jul 25, 2006 7:11 am    Post subject: Reply with quote
I have an Oil sender in my oil drain hole. Its a VDO sender and the max is arround 180 degrees Celcius. The oil gauge is a normal VDO Vision.
Porsche 924 Euro 1977
Chrenan
PostPosted: Tue Jul 25, 2006 7:34 am    Post subject: Reply with quote
Is 180 the max on the gauge, or the max you see when running the car? What oil temperature does the car get to while running?
PostPosted: Tue Jul 25, 2006 2:40 pm    Post subject: Reply with quote
mine runs around 85 celcius... although some people regard max power is achieved at a slightly higher oil temp...
Pretty sure my bolt hole was an M14 X 1.5 too...
Leadfoot
Chrenan
PostPosted: Tue Jul 25, 2006 11:52 pm    Post subject: Reply with quote
Thanks leadfoot, that helps.
Meneer aard
PostPosted: Wed Jul 26, 2006 5:19 am    Post subject: Reply with quote
The maximum of the gauge is arround 150..
When i drive it normal under normal conditions (20 degrees celcius temperature) the oil is arround 85-90 dregrees). When i drive quick (arround 180 or rev it high) it is arround 100 dregrees. With outside tempertures of 32 degrees the oil is arround 95 under normal driving.
