permanently damaged?
doomer77
PostPosted: Sat Jun 03, 2006 9:03 pm    Post subject: permanently damaged? Reply with quote
my car has had its ups and downs, and now it might be in for the final judgement..
couple of months ago my front wheel stabilizer bar started making clacking sounds that got worse and worse over time, solution: change it. however the car has been crashed (long time ago, repaired now) and the bodywork is a little bit bent out of shape, could it be that the bent body is causing the stabilizer to break prematurly. in this case i would have to put a new one in every few months.. and the car would not be of much good
Why drink and drive when you can smoke and fly?
Carpe diem. and if that doesnt work; get drunk!
1980 924 n/a - engine swap begun
1989 Volvo 480ES
Stampedetrail
PostPosted: Sat Jun 03, 2006 9:08 pm    Post subject: Reply with quote
Maybe use a better heavy-duty stablizer bar setup instead of junking the frame. Just a thought.
1977.5 924 "Martini" head / New Old Stock rebuild
1985.5 944 Why? Because I can.
PostPosted: Sat Jun 03, 2006 9:12 pm    Post subject: Reply with quote
Sway bars never break, they can be bent, but I've never seen one break.
Are you talking about the end links?
PORSCHEV
PostPosted: Sat Jun 03, 2006 9:18 pm    Post subject: Reply with quote
Try changing it once....I am sure that will be the end of it for years.
1978-#53 "D" track racer.
doomer77
PostPosted: Sun Jun 04, 2006 2:22 am    Post subject: Reply with quote
ill try it and i sincerly hope so..
1989 Volvo 480ES
