Chrenan
Posted: Fri Mar 03, 2006 1:08 am Post subject: Battery Tray Repair (Minor Rust) |
Battery Tray Repair (Minor Rust):
BATTERY REMOVED -
BATTERY HOLD DOWN BRACKETS REMOVED -
START SCRAPING OLD COATING AWAY -
OLD COATING REMOVED--READY TO SAND -
SANDED--READY FOR PRIMER -
PRIMER APPLIED -
RUBBERIZED COATING APPLIED -
 _________________ 1987 951 - M193 Version for Japan |
Guest
Posted: Fri Mar 03, 2006 11:07 am Post subject: |
on mine I removed all the old rubber coating on the battery tray but not up to the winshield area (rubber coating goes all the way up.).
I removed my old coating sanded it with an electric sander mine wasn't rusty at all in the middle section but on the edges I found one spot I could poke throught I primed only that spot then let it dry, filled it with steely. then I just painted my whole battery tray with por15, it looks like it has held good so far, it hasn't chipped or anything. |
Matt Norton
Joined: 14 Apr 2006 Posts: 196 Location: Montour Falls/Watkins Glen NY
Posted: Sat Apr 22, 2006 12:00 am Post subject: |
Mine doesn't seam to be rubberized. I have a small hole right in front of the
battery. It leeks right into the passenger side floor. Fill up the battery tray
and watch it come him. What do you use as a rust stopping/ prohibiter/
primer on the battery tray and floor panels of a 924S and what was that stuff
you used to plug the whole? _________________ Red 1987 924S with plans for D Productions Kit
From American International Racing. |
CBass
Posted: Mon Jul 24, 2006 6:33 am Post subject: |
I should post up some pics of mine... Oh lawd. _________________ '81 931 in various states of assembly |
