pmcaya2
Joined: 24 Nov 2005 Posts: 191 Location: Scio, NY USA
Posted: Sun Apr 02, 2006 1:44 pm Post subject: Steering U-Joint Repair & replacement |
Seems like my 1982 924 with ablut 150K miles has a problem with the upper steering U- joint where it attaches to the steering column. There is a dead spot when the wheels are pointed straight ahead. You can move the wheel a bit (2-3 inches) before the upper U-joint moves. It moves the rack normally on either side of this dead spot. The rack-and-pinion and lower joint are fine. I have a Haynes guide, but I need your help and advice about obtaining the parts and doing the job. Thanks in advance. - Peter
P.S. Even though my insurance is paid up, my wife forbade me to drive it and my brother-in-law said he would buy insurance on me if I did. I don't think its that bad if you keep it under 60/ mph - you sort of get used to it ... like driving on the left.... |
Posted: Sun Apr 02, 2006 1:51 pm Post subject: |
Park it please!
The easiest thing to do is to find a good used steering shaft with both U joints. Try posting in the parts wanted section. _________________ White 87 924S "Ghost"
Ozzie
Posted: Sun Apr 02, 2006 3:11 pm Post subject: |
From what I have read the uni joints are not repairable and you have to replace the shaft.
Also there is 2-3 different types of shaft. Look the same but different lengths. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
pmcaya2
Posted: Mon Apr 03, 2006 12:12 am Post subject: Steering U- Joint Repair |
| I was only kidding about driving it - thanks for your concern. Replacing the steering column looks like the devils own job - probably need to remove the brake vaccuum booster just to get started. Is this a rare problem? has anyone done this before? - Peter |
Posted: Mon Apr 03, 2006 12:15 am Post subject: |
Assuming it's a US car, it's about 1/2 hour job to change the shaft. It's held on by only 2 bolts!
Very common problem, especially on 931s with 205 tires. _________________ White 87 924S "Ghost"
pmcaya2
Posted: Mon Apr 03, 2006 12:29 pm Post subject: |
| Thanks Paul. Its only 2 bolts after you disconnect the U-Joint! It might be a half hour job to remove the steering column after you loosen the U-joint pinch bolt and the vacuum unit. Per my first post, I need your help and advice about obtaining the parts and doing the job. |
Posted: Mon Apr 03, 2006 1:31 pm Post subject: |
Is this a US car? We all appreciate if you at least put the country where you live in your profile or signature.
It's really 6 bolts and it can all be done in minutes without removing the the booster.
First spray everything with PB blaster or Liquid Wrench.
You need to remove the 2 thru bolts on each U joint and the 4 bolts that hold the steering rack to front cross member.
Once all this is done just pry the U joints off the rack and the steering shaft. Then remove the shaft with the U joints in one piece. _________________ White 87 924S "Ghost"
Posted: Mon Apr 03, 2006 1:41 pm Post subject: |
It looks like this:
Porscheaddiction
Joined: 03 Nov 2002 Posts: 431 Location: Cornwall, Ont, Canada
Posted: Mon Apr 03, 2006 2:39 pm Post subject: |
takes only minutes.I like that comment, I took me quite a few hours there is not much room to work on the upper u-joint bolt, but once u have that nut and bolt off u drop the steering rack a bit and the shaft normally just falls off from the top connection. remove the bottom u-joint bolt and lift, it normally comes right off as well. the fun part is installing the new one. slide the top u-joint on hold on to it and with your other hand bring up the rack and slid the bottom u-joint in position, (I found it eaiser to use a hydrolic jack to lift and keep the rack in position) once both the bottom and the top are on u can bolt the rack back into place. Now bolt your bottom ujoint on, now for the fun part rebolt the top u-joint. torque everything to spec, Drop down the car center your wheels and make sure your steering wheel is centerd . if not. unbolt the steering wheel center it and retorque it to spec. YOUR done enjoy the better "tighter feel" while u drive.
Good luck
Chris. _________________ 1981 924 NA (Restoring mode)
1984 928S (Enjoying the driving season) |
Ozzie
Posted: Mon Apr 03, 2006 5:52 pm Post subject: |
ITs a little trickier with RHD but its easy once you get to the bolts. _________________ Porsche 924 1984 (UK import) NA
Mike924
Posted: Tue Apr 04, 2006 5:40 pm Post subject: |
Hey, Pete,
before you fork out good money for a new shaft, just make sure th play isn't right at the steering wheel. If the nut holding the steering wheel becomes loose (even a little bit), you can start to get a couple of inches play in the steering. Check this fist - it may save you a few dollars (presumably; we still don't know where you're from! ) _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org |
pmcaya2
Posted: Wed Apr 05, 2006 10:07 am Post subject: Steering U-Joint repair and replacements |
| First of all, thanks to all for your help and patience - esp Paul. I live in western NY and intend to take another crack at the steering this weekend, when/if it warms up. It has a 5 speed manual and no power steering. I managed to loosen the top u-joint pinch bolt, so I should be able to remove it and the steering column as you suggested. I'll also check the steering wheel nut, but I think that its tight. Thanks for stopping me from removing the brake booster . I'll be back to update. - Peter |
Posted: Wed Apr 05, 2006 10:43 am Post subject: |
You've got the hardest part already done (the top U joint bolt)! _________________ White 87 924S "Ghost"
pmcaya2
Posted: Tue Apr 11, 2006 1:02 pm Post subject: Steering U- joints |
Update: I loosened the top U-joint, and I thought that I could seperate it from the steering column after I disconnected the steering rack. I can turn the u-joint nut with a trick socket but the bolt turns also. How do your loosen/tighten ths upper U ?
Another thing: what generally strips , the shaft or the steering column? |
