Fire Seal 2000 for cracked 931 exhaust manifolds?
PostPosted: Thu Mar 30, 2006 6:54 am    Post subject: Fire Seal 2000 for cracked 931 exhaust manifolds? Reply with quote
I wonder if this stuff would hold up on a cracked 931 manifold -
http://www.prp-porstore.com/POR-15-Fire-Seal-2000.html
(I don't have a cracked manifold (as far as I know), just wonder if it would work..)
Tigger937
PostPosted: Thu Mar 30, 2006 8:41 am    Post subject: Reply with quote
Great find if it works. Approximately, what is the temp. of a red hot exhaust manifold?
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Raceboy
PostPosted: Thu Mar 30, 2006 3:37 pm    Post subject: Reply with quote
It should be somewhere 1000-1200 C, but I could be mistaken.
Anyway, this is a nice find indeed.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
-nick
PostPosted: Fri Mar 31, 2006 4:10 am    Post subject: Reply with quote
Only one way to find out- buy the quart container of this stuff, dip the whole manifold in it, and take it out for a few runs
Seriously though, it's definitely worth a try. I have an extra manifold with a crack if anyone wants to try it out.
nick
Motorheadmike
PostPosted: Thu Apr 06, 2006 2:18 pm    Post subject: Reply with quote
For $15 and shipping I'll bite
Nick, What do you want for the cracked manifold?
Mike
1981 931 series2
Vince Ponz
PostPosted: Thu Apr 06, 2006 11:48 pm    Post subject: Reply with quote
I had mine welded for $200. He seemed to know what he was doing.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
-nick
PostPosted: Fri Apr 07, 2006 1:37 am    Post subject: Reply with quote
PM sent. Mike might be our guinea pig
nick
PostPosted: Fri Apr 07, 2006 2:58 am    Post subject: Reply with quote
http://www.bankspower.com/sidewinder/Tech_whyegt.cfm wrote:
, what constitutes excessive EGT? If everything is working properly, 1250º to 1300º F. is a safe turbine inlet temperature, even for sustained running, mile after mile. Above 1300º F. things can start to get edgy. Remember, excessive EGT damage is cumulative. Over 1400º F., you’re usually gambling against a stacked deck and it’s only a matter of time until you lose. The higher the EGT, the shorter that time will be.
That's talking about diesel turbo engines though.
-But pyrometers (EGT gauges) sold here generally cover 0-1600ºF, so it should be safe to say that manifold temps normally fall within that range.
As for "red hot", I haven't found anything on what approx. temp. you're at when things start to glow - http://saabnet.com/tsn/photo/0202.html
Kenodog
PostPosted: Tue Apr 11, 2006 1:50 pm    Post subject: Reply with quote
2000 degrees is pretty freakin hot.We were heat treating some 4140 at school and at 1500 deg. F it was almost white hot.
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Tigger937
PostPosted: Tue Apr 11, 2006 9:58 pm    Post subject: Reply with quote
I'm not a metallurgist, but don't different materials glow differently at the same temperatures? Just asking.
1981 931 (Concours)
Benino
PostPosted: Fri Apr 14, 2006 8:31 am    Post subject: Reply with quote
so. . . . is anytone testing this out?
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Fri Apr 14, 2006 11:17 am    Post subject: Reply with quote
Yes. For example stainless steel goes through a completely different colour change compared to mild steel.
Mild steel at 1500F is described as a "bright" red. At 1900F it's bright yellow and at 2100F it's white. Stainless goes black at 1000F and only changes to a dark red before it melts at 2600F.
Most welding books have a table showing temp vs colour although usually only for mild steel. A google session should turn up some charts if you're interested.
9magazine
PostPosted: Mon Dec 31, 2007 6:33 am    Post subject: Reply with quote
Any update on this product?
Brian
9magazine.com
View user's profile Send private message Visit poster's website Yahoo Messenger
randy_eich
PostPosted: Tue Jan 01, 2008 11:38 pm    Post subject: Reply with quote
Go to your local Caterpillar store and you can get the same stuff off the shelf. I tried it on a 3508 turbo outlet and after it got hot, it just crumbled off. So I really don't think it will hold up. Diesel exhaust manifolds don't run very hot. I can light a smoke off gas, but not diesel.
