Struts
Tigger937
PostPosted: Sat Mar 04, 2006 12:45 am    Post subject: Struts Reply with quote
Anyone know what modifications, if any, can be made to 951 front struts to fit on a 931 S2? Is this possible?
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
Raceboy
PostPosted: Sat Mar 04, 2006 1:27 am    Post subject: Reply with quote
It is, but you have to change upper mounts (4 8mm bolts) and modifythe strut-to-spindle mounting holes. On 951, the distance is 5mm bigger, it means you have to enlarge the hole. It's been done before, no ill effects. Don't you want to change to 951 brakes? It would make things much easier.....
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Tigger937
PostPosted: Sat Mar 04, 2006 1:37 am    Post subject: Reply with quote
Sounds simple enough. 4 piston calipers? Hmmmmmmm...................sounds worth while. How would changing to 951 brakes make the job easier? Fill me in, please!
1981 931 (Concours)
Tigger937
PostPosted: Sat Mar 04, 2006 4:30 am    Post subject: Reply with quote
OK, did some searching in the archives. (Should have done this first. ) Now I follow you. Changing brakes requires 951 spindles (for mounting the larger calipers), hubs and rotors which would have the correct mounts for the struts, therefore, no modification of the strut-to-spindle mounting holes would be necessary. Would this work OK with the stock brake hydraulics?
1981 931 (Concours)
Raceboy
PostPosted: Sat Mar 04, 2006 5:12 am    Post subject: Reply with quote
Yes it will be ok, I've done this number of times, no problems. Of course, new pads and hoses wouldn't hurt
I changed suspension to 87- on my 931 and used steel front A-arms and alloy rear amrs (like 924 S).
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Tigger937
PostPosted: Tue Mar 07, 2006 4:59 am    Post subject: Reply with quote
Thanks for the help!
1981 931 (Concours)
