51 head on a 24s
Modoc
PostPosted: Sat Dec 31, 2005 3:07 am    Post subject: 51 head on a 24s Reply with quote
ok so everyone talks about a 931 head on a 924 what about a 951 head on a 924s? anything keeping someone from doing that? anyone tried it before... I've got a place where I could possibly get the head what do you guys think ? worth it?
Proud owner of
'88 924s - Sold
'01 ML430
'97 Honda Civic
special-tool
PostPosted: Sat Dec 31, 2005 8:50 am    Post subject: Reply with quote
Not worth it. Slightly different port shape - which might actually HURT you.
Get a wideband, SMT6 and a Milledge cam and you will see some significant power gains.
I have had the wideband on my 87 924S and the fuel tuning was not really that good. It was up around 14 too much especially without the cat.
951 566/485 HP/TQ at the wheels - pump gas
924S GTR conversion project
Honda 250R- PWK 35mm flat slide, 205 static, Boyesen, Wiseco, DG front/back, Uni, 14/42,
CBass
PostPosted: Mon Jan 02, 2006 6:30 am    Post subject: Reply with quote
Why not just go 3.0 DOHC instead? The reason for going to a 931 head from a NA is because the 924 head is junk in at least a half dozen different ways.
Terrible ports, terrible combustion chamber, terrible cooling etc.
The 944 head is no Formula 1 piece, but there's nothing really WRONG with it. If I was to look at swapping bits and pieces in a 944/924S, I'd look at the 3.0 DOHC engine. 240hp in 968 trim, a little tuning can get you more, the sky is the limit. I don't think a 3.0 DOHC head swap would result in a favourable compression ratio with a 2.5 8v 944 bottom end however.
special-tool
PostPosted: Mon Jan 02, 2006 11:20 am    Post subject: Reply with quote
Good idea - but the 968 and the S2 head do not fit on the 2.5 block.
The 968 is by far the best 4 cyl Porsche head ever made.
If you wanted a DOHC head on a 2.5 block, you need the 2.5 liter S head - that is a direct fit.
Kevin D
PostPosted: Sun Feb 05, 2006 1:20 pm    Post subject: Reply with quote
Best solution is to just get the whole 3L and 6sp put in the 924. Bolts right in.
'88 924S 3L 6sp RedRat
'92 Duc 900ss
'02 Duc 998 Carbon
'72 RD 350
Modoc
PostPosted: Mon Feb 13, 2006 2:57 pm    Post subject: Reply with quote
good to know
next question, price quote on that please? how much did it cost you?
Proud owner of
'88 924s - Sold
'01 ML430
'97 Honda Civic
Kevin D
PostPosted: Tue Feb 14, 2006 3:07 am    Post subject: Reply with quote
Actually, I bought it from the guy that did it and then decided to just buy a 997, so cost was never really an issue for him. Judging from the reciepts I've gone through, this isn't an economical option. He paid around $7000 for the motor and tranny (with tt) delivered and has about 100 hours into the swap. The mechanics were a straight bolt in, no custom adaptors/mounts needed. It's hard to tell exactly where the 924 ends and the 968 begins. He put in a larger 944 radiator and the 968 brain. I have some funky wiring diagraming, but beyond that it seems a simple, if not economical swap. I still have to figure out the tach (simple) and the cruise control (not too important). In the meantime, it's a fun sleeper. I keep in contact with the previous owner and his mechanic/buddy here, so I'd be glad to get better details if needed, but I doubt this is really the best solution to finding power.
'92 Duc 900ss
'02 Duc 998 Carbon
'72 RD 350
Llamaguy
PostPosted: Tue Feb 14, 2006 7:47 am    Post subject: Reply with quote
doesn't the 951 head have some funky ports, something about coming out the wrong side of the head or something.
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
