O2 sensor on an 82 931
rdjohnston50
PostPosted: Sat Feb 11, 2006 8:35 am    Post subject: O2 sensor on an 82 931 Reply with quote
Can the existing ceramic plug where the O2 sensor connects to the harness be replace with a simple single pole connector? The wireing diagram shows a single wire with what appears to be an outer strand for grounding? It crumbled in my hands. If not, what's the part number for either the plug or the entire wire? I've got the PET 5 but can't find any part number.
PostPosted: Sat Feb 11, 2006 9:06 am    Post subject: Reply with quote
That's a co-axial wire with the outer wire serving as an interferance shield. In OE form, it's grounded only at the lambda box under the dash. For the wire, a good substitute would be automobile co-ax antenna wire from some place like Radio Shack.
If the connector's shot, I'd use something like this -
http://www.radioshack.com/product/index.jsp?productId=2104095 -and not just crimped, but soldered. -Then sealed with a good dose of dielectric grease.
rdjohnston50
PostPosted: Sat Feb 11, 2006 10:15 am    Post subject: o2 sensor Reply with quote
I thought it looked like a coaxial cable but wasn't sure. Thanks for the reply, I do appreicate it
