bass gt
Posted: Sat Feb 04, 2006 11:04 am Post subject: Wastegate Operation |
Guy's,
A quick question please. My wastegate has a pressure line running from the top of the housing to the charge tube. Is this a line FROM the W/G or TO the W/G???
ie, if the former, am i right in assuming that if this line is closed/blocked, the W/G cannot vent and will over boost? or do i have it arse about face??
Cheers,
Steve |
Posted: Sat Feb 04, 2006 11:13 am Post subject: |
The pipe on the top of the wastegate is a vent.
The pipe from the charge tube should be connected to the fitting on the side of the WG.
If the vent is blocked, the wastegate will allow more boost than it should. _________________ White 87 924S "Ghost"
bass gt
Posted: Sat Feb 04, 2006 12:02 pm Post subject: |
Strange,
I have a copper pipe which comes from the top of the W/G up behind the engine, along the head and connects into the the charge tube.????
I have the feeling something is amiss here. Anyone got any pics??
Steve |
Posted: Sat Feb 04, 2006 12:25 pm Post subject: |
No pics, but Paul's right. The top-center is a vent. If there's a connection from there to the charge tube, then that's bassackwards. Pumping air in that way would only keep the wastegate closed. The charge tube to WG connection should go into the WG at its' side, lower down, below the bell-shaped spring&diaphragm housing. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Sat Feb 04, 2006 1:35 pm Post subject: |
The vent pipe in its stock location terminates with a J pipe bolted to the rear of the head.
Maybe your car has a boost controller attached to your vent line before it gets to the charge tube? _________________ White 87 924S "Ghost"
sequential
Posted: Sat Feb 04, 2006 5:41 pm Post subject: Re: Wastegate Operation |
| bass gt wrote: | Guy's,
Cheers,
Steve |
Hello Steve,
On The DTA systems with boost valve control the boost valve is connected directly to the top of the wastegate. So if you plan to use an Electro-mechanical control of your boost this is where you will connect it.
WITH BOOST VALVE
1. boost from the manifold straight to the lower chamber of the wstegate .
2. Boost from the valve straight to the top of the wastegate.
NO VALVE
1. Then no connection to the top of the wastegate ( now only as a vent )
2. Direct connection only to the lower chamber of the wastegate.
( spring pressure value only ) _________________ 928 gts prototype
baby blue engine block
steam in 1,2,3,4 sometimes
cold star issues while on stands
112 whp with new 4 valve head and MIS 2 |
u63af
Joined: 19 Apr 2005 Posts: 105 Location: Aberdeen, (Scotland)
Posted: Sat Feb 04, 2006 8:58 pm Post subject: |
| I have the type with the control line going to the bottom of the waste gate. When i put in a boost controller (the sort with the ball bearing and spring) the car overboosts even if i have the spring on its loosest setting. Is this a normal problem with the 924 turbo or do i have something wrong with mine? |
sequential
Posted: Sun Feb 05, 2006 2:32 am Post subject: |
| u63af wrote: | | I have the type with the control line going to the bottom of the waste gate. When i put in a boost controller (the sort with the ball bearing and spring) the car overboosts even if i have the spring on its loosest setting. Is this a normal problem with the 924 turbo or do i have something wrong with mine? | \
read the post above, valve to the head of the wastegate only. _________________ 928 gts prototype
bass gt
Posted: Sun Feb 05, 2006 4:07 am Post subject: |
Cheers Guy's!!
Yep, there is a manual valve in the vent line, which then connects to the charge tube. Obviously, with this valve shut, the W/G cannot vent, hence overboost. I've since found the valve is faulty, and is pretty much blocking the line to the charge tube.
I'm going to look into the various type of EBC's, and make a decision for or against. If they really are as good as the blurb says, they must be worth it? Or is it all smoke and mirrors, and another electro wizzy gimik for our ricer friends?? wooosh wwwwooooooooshhhh
Regards,
Steve |
Posted: Sun Feb 05, 2006 5:14 am Post subject: |
Actually there are at least 2 ways of installing a simple control valve and I think at least half of us that are using one have it in the control line, with the top WG port being left open as a vent. This is the quickest-easiest way of hooking it up. It works, but is probably functionally a second best to the next arrangement -
Control line from charge tube to bottom-side of WG is left alone and the valve is placed in-line from the vent port with the flow direction going away from the WG (if the valve being used is directional), but the other end of this vent line downstream of the valve is left open to atmosphere - it's not connected back to the charge tube (doing so would render the WG inoperable since you'd be pumping charge air into the top and bottom of the WG at the same time).
As far as the electro wizzy gimik thing - I think it is for the most part. I'd go with a simple $5 needle valve like numbbers is using. Try it, you'll probably like it. If not, it was only $5...remove and put it to use on a fish tank, or drip irrigation for your plants and replace with an EBC. _________________ "..it's made in Germany. You know the Germans always make good stuff."
sequential
Posted: Sun Feb 05, 2006 6:26 am Post subject: |
| bass gt wrote: | Cheers Guy's!!
Regards,
Steve |
Steve ,
Use the emerald to control the boost with a electro-mech valve .
then it is all software operated. you can use this method to shape your torque curve. _________________ 928 gts prototype
bass gt
Posted: Sun Feb 05, 2006 9:49 pm Post subject: |
Wayne,
I'm looking into the DTA P8Pro at the moment. Seems to do a few things that the lower end units don't. Whats your take on this unit?
Steve |
sequential
Posted: Mon Feb 06, 2006 2:58 am Post subject: |
| bass gt wrote: | Wayne,
Steve |
If your series allows traction control go with the pro 8 , if not use the S60.
I can provide you with start and run maps that would get you close to the ideal. If you decide to go with the dta contact me via email i will setup or advise you on the package needed, their web addy in case you do not have is www.dtafast.co.uk or of course mine here in the us www.tpgproducts.com
you will be able to pull all the info you need from both. _________________ 928 gts prototype
bass gt
Posted: Thu Feb 09, 2006 7:05 am Post subject: |
Wayne,
I think it may be the S60 i go for, and add the RaceLogic TC system later. It has much more adjustability than the DTA. However, the S60 does exactly what i want. As for the maps, thanks, i will drop you a line closer to the time.
Steve |
