Pca944
Posted: Sun Feb 19, 2006 6:50 am Post subject: DXS? |
Hi,
There is a small yellow light that says "DXS" on the top of the guage cluster of my 82' 931. What does that stand for? I'm guessing its for the high beams, but I'm not certain. _________________ 1986 944 | 1978 924 (FS) | 1982 931 | 1980 931 |
Tigger937
Posted: Sun Feb 19, 2006 6:59 am Post subject: |
OXS=Oxygen Sensor. It's warning light that says it's time to replace your sensor. It trips every 30,000 miles and is reset by a button underneath a black box on the left front wheel well that has a speedo cable going to/from it. _________________ 1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box" |
Posted: Sun Feb 19, 2006 7:01 am Post subject: |
It's saying you've gone more than 30,000 miles since you reset your O2 mileage counter.
Actually it's there to remind you to replace the O2 sensor.... _________________ White 87 924S "Ghost"
Pca944
Posted: Sun Feb 19, 2006 7:02 am Post subject: |
Thanks. _________________ 1986 944 | 1978 924 (FS) | 1982 931 | 1980 931 |
Ozzie
Posted: Sun Feb 19, 2006 11:41 am Post subject: |
In OZ we dont have an O2 sensor and its an extra high beam indicator.
just a FYI.
Strange - one turn indicator but 2 high beams. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Tigger937
Posted: Sun Feb 19, 2006 4:08 pm Post subject: |
| Ozzie wrote: | In OZ we dont have an O2 sensor and its an extra high beam indicator.
just a FYI.
Strange - one turn indicator but 2 high beams. |
You guys get all the neat stuff. _________________ 1981 931 (Concours)
Posted: Sun Feb 19, 2006 4:10 pm Post subject: |
Early US 924s (no O2 sensors) had a second high beam indicator too... _________________ White 87 924S "Ghost"
Ozzie
Posted: Mon Feb 20, 2006 7:31 am Post subject: |
I rewired mine and put in 2 turn signals _________________ Porsche 924 1984 (UK import) NA
Posted: Mon Feb 20, 2006 8:22 am Post subject: |
Sad, the Dr assumed all Porsche owners were smart enough to know which way they moved the turn signal lever.....  _________________ White 87 924S "Ghost"
Llamaguy
Posted: Mon Feb 20, 2006 9:22 am Post subject: |
why would you tell the people chasing you which way you're going to turn anyways? _________________ 1987 924S Guards Red
1997 Suzuki Tl1000 Supersport |
Ozzie
Posted: Mon Feb 20, 2006 12:16 pm Post subject: |
Actually the turn signals stopped working yet would work with the hazard/emergency flashers.
All the globes were ok and the flasher worked when the hazard switch was on.
I spent several days with the turn switch apart, checking wiring etc and ended up putting a separate flasher and indicators under the dash.
The light in the guage works with the hazards and the L and R lights work with the respective turn signal. _________________ Porsche 924 1984 (UK import) NA
Mike924
Posted: Thu Feb 23, 2006 6:13 pm Post subject: |
Great minds think alike, Ozzie!
When I first saw those blank buttons on the 924 dash, I thought that's just screaming out to have separate turn signal indicators there!
However, unlike you, I still haven't done anything about it. Good on yer, Mate! _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
endwrench
Posted: Fri Feb 24, 2006 3:53 pm Post subject: |
| Ozzie wrote: |
I rewired mine and put in 2 turn signals |
Someone has way too much time on there hands!
Todd |
Ozzie
Posted: Fri Feb 24, 2006 5:55 pm Post subject: |
| endwrench wrote: | | Ozzie wrote: |
Todd |
As I said I had a wiring fault I couldn't find- this was a work around. _________________ Porsche 924 1984 (UK import) NA
