Uprated discs
monkeyminge
PostPosted: Tue Jan 03, 2006 11:02 pm    Post subject: Uprated discs Reply with quote
Anyone have any links to uprating front discs on 4 lug 924?
Just keep getting NO all the time
gohim
PostPosted: Wed Jan 04, 2006 6:03 am    Post subject: Reply with quote
I think that ATE makes/sells their slotted discs that will fit the 924's front solid rotors.
BUT, the upgrade for the 924's four-lug solid front disc brakes IS the five-bolt ventilated front disc & ventilated rear disc brake system from a late 931 or 944.
This has been discussed many times in the past, and a simple search will provide you with many viewpoints on this upgrade. The cost could now be as low as $200, if you live in the U.S. and pull the brake parts, tires, and wheels from a salvage car yourself in a Pick A Part self-service junk yard.
That's close to what a pair of the ATE "Power Slot" rotors will cost you.
Dans931
PostPosted: Tue Jan 24, 2006 9:00 am    Post subject: brake conversion Reply with quote
If you decide to change over, insure that you get the parking cable from the donor car; they are different. The improvement in the 5 lug brakes is no less than amazing.
Daniel
Vince Ponz
PostPosted: Mon Jan 30, 2006 3:39 am    Post subject: Reply with quote
I wish you guys would learn to put in your town. Who is looking for you?
Anyway if you were near I am taking a 944 apart and the 5 bolts are up for graps.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
