Low Boost Reading
ossaman55
PostPosted: Sat Nov 11, 2006 11:49 pm    Post subject: Low Boost Reading Reply with quote
I just got my boost gauge installed in my 931. I got one because i suspected that i was not getting the same level of boost that i was getting before the turbo rebuild. The gauge is reading about 7psi, which i believe is low. I think my wastegate may be stuck open. When the old turbo broke its shaft tons of oil was pumped everywhere? Has anyone had problems with a sticky wastegate, and what knid of boost would i be getting if my wastegate was stuck open
Darren
1980 931
1984 Maserati Biturbo
1978 Triumph Spitfire
1986 Camaro Z28
PostPosted: Sat Nov 11, 2006 11:58 pm    Post subject: Reply with quote
Sounds about right, if you haven't modded it - 0.5bar.
Where in MI are you??? Put it in your profile!!
ossaman55
PostPosted: Sun Nov 12, 2006 4:16 am    Post subject: Reply with quote
Thanks for the response. Im in Imlay City, about 40 miles north of Detroit.
Darren
1980 931
1986 Camaro Z28
PostPosted: Mon Nov 13, 2006 12:17 am    Post subject: Reply with quote
Yep, I'm 46 miles right south of you!
