Exhaust systems
Goto page Previous  1, 2
N-Dub
PostPosted: Wed Jan 25, 2006 2:59 pm    Post subject: Reply with quote
In my great state of Utah, the law does not require my car to have a catalytic convertor. I ripped off my cat, resonator, and muffler with all pipes. I then had a 2.25" pipe from where the cat was all the way back to a Magnaflow flow through muffler. I noticed quite a gain in power. It revs faster, flows better, accellerates faster, raised my top speed, sounds louder, and gargles like a racecar when you let off the gas. It was the best $300 I have spent on my car after initial purchase!
'79 924 now Totaled! Carrera GT bodywork for sale!
'87 951
Khal
PostPosted: Wed Jan 25, 2006 4:42 pm    Post subject: Reply with quote
Ah, the sense of hearing is a wonderful thing!
Have you had before and after dyno test to prove the increase horsepower? It's not that I don't believe a good exhaust can make an engine feel better, and in some cases release a good deal of neddies. It's just that I agree with gohim in that I've read a bit about "bolt-on" upgrades for the 924 and they all make very little difference. A few hp tops.
On the other hand, have you ever watched a scary movie? You know when they have the dark, ominous music rising in the background just before the door SLAMS SHUT!
Gets you all tense, doesn't it? If it's done well, it'll scare the **** out of you!
Watch the same scene with the sound off... dull
Same thing can happen when you put a performance exhaust on you car. The engine sounds meatier, racier. And it gets you hyped. But you're not really going any faster... just sounds like you are
I've got nothing against a performance exhaust. I've got one on my car and it sounds great I love it.
But I doubt it's giving me huge amounts of horsepower...
'80 924 Turbo
Min
PostPosted: Thu Jan 26, 2006 10:21 am    Post subject: Reply with quote
Well khal, if he says it feels stronger, it probably is. Just becuase he gets a max hp increase of 1-2hp, doesn't mean that the car doesn't improve throughout its entire rpm range with a good working exhaust. For all you know, his previous exhaust was made of pot metal and bubblegum, making his car feel like a dog. Just having a good working exhaust system when you previously had a badly working one can seem like the car gains huge power, when in fact you've just recovered the lost power you didn't have becuase of a poor rotting/rusted system. Chances are he installed a exhaust system becuase he needed one.
Min
N-Dub
PostPosted: Thu Jan 26, 2006 11:32 am    Post subject: Reply with quote
My exhaust was not made of bubble gum. It was Orbit. Just kidding. The previous exhaust system was the stock factory system. There were no dents to restrict flow, it was a fine system. I did not need a new system, just realized that would be a good way to gain power. The new one was not just new piping and a muffler, it included removing the cat and resonater. Those alone create a significant differences. All this combined, I am bold enough to say, took more than two seconds off of my 0 - 60 time.
'87 951
Khal
PostPosted: Thu Jan 26, 2006 12:23 pm    Post subject: Reply with quote
You're right, it probably is. As I said...
And I did read your post, N-Dub. But I completely missed that you removed cat. and resonator. Yes, of course that will make a big difference.
We don't have cat's on our cars down here so I wasn't even thinking about it... sorry.
I still maintain that the sound of a car definitely affects your perception of its perfomance. That's not a bad thing, it's good! It's all about the "feel".
Two seconds quicker to 60, though?! That's mighty impressive!
'80 924 Turbo
DS-777
PostPosted: Thu Jan 26, 2006 12:39 pm    Post subject: Reply with quote
Thats impressive, a new Windblown kit on a relatively new 924 only decreased 0-60 by like 3.5 seconds; From 11 down to 6.7.
http://www.geocities.com/the_924_site/WindBlown.htm
Gone: 1981 silver 924 w/ black int. and a 5 speed.
Min
PostPosted: Thu Jan 26, 2006 1:02 pm    Post subject: Reply with quote
I'd say 2 seconds from a simple exhaust system change (from a correctly working system to a 'performance' system) is a bit far fetched.
Min
N-Dub
PostPosted: Fri Jan 27, 2006 8:56 am    Post subject: Reply with quote
I have done time runs and it is very close to two seconds.
'87 951
PostPosted: Fri Jan 27, 2006 12:55 pm    Post subject: Reply with quote
Your convertor must have been severly clogged.
PostPosted: Fri Jan 27, 2006 6:26 pm    Post subject: Reply with quote
N-Dub so whats your 0-60mph 0-100kmph time now ?
PostPosted: Sat Jan 28, 2006 5:36 am    Post subject: Reply with quote
Thats about what I hit on my g-tech timer last spring, with two people in the car and a bogged launch.. I'd guess that the wb turbo kit bumps it up to Turbo US spec numbers.
I'm curious to see what my car will do in the spring time with the short shifter and non bouncy suspension and exhaust. high 5's..
endwrench
PostPosted: Sat Jan 28, 2006 3:16 pm    Post subject: Reply with quote
That's pretty good flosho. If you are doing 6.7 sec your ahead of the average according to the magazines: http://www.weissach.net/924-944-968_RoadTestSummary.html . Most were 7.5 to 9.3 seconds for the American 931. I tested one yesterday, a 1980 with 41,000 original miles, and it could barely break 9 seconds. I was not abusive to it though. I shifted at 6000 rpm and never broke the tires loose with no speed shifting. I am also at 3500 feet elevation wich is good for about 2lbs less boost.
Todd
PostPosted: Sat Jan 28, 2006 11:23 pm    Post subject: Reply with quote
i could never get my 924 NA to clock (by hand) under 10 seconds
..weird thing is that i have a small plate near the batery that says that the weight of the car is 1450 KG thats like 3196 lbs !! is this posible for an euro car ?
Belgian924t
PostPosted: Sat Jan 28, 2006 11:55 pm    Post subject: Reply with quote
That weight is the total weight with passengers, luggage and fuel included. In Belgium that is called "MTM" : Maximum allowed mass.
It is not the weight of the car dry.
Greetz
'79 931 with Carrera GT look
'86 944 turbo (sold)
'88 944 turbo S (sold)
'85 911 Carrera 3,2 (to be restored)
'80 911 SC "SOLD"
http://www.cardomain.com/ride/2224272
Page 2 of 2
