daniel
Joined: 18 Jun 2009 Posts: 669 Location: Sydney, Australia
Posted: Thu Sep 10, 2009 10:04 am Post subject: Performance Downgrade!! 5 speed - 4 speed |
Hi all
My car is a November built 77 factory fitted with the Getrag 5 speed box. I am arguing with CAMS (similiar role to the US SCCA) over here in Australia regarding the cars eligability as a Historic production sports car.
I may have to change it back to a 4 speed gearbox as part of the eligability. So what I would like to know is, what is required to swap to a 4 speed?
1) Are the mounts the same?
2) Are the drive shafts the same length?
3) Is the shift linkage the same?
Cheers!
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Khal
Joined: 26 Sep 2003 Posts: 4869 Location: Sunny and lovely interior BC, Canada
Posted: Thu Sep 10, 2009 10:12 am Post subject: |
daniel wrote: | My car is... factory fitted with the Getrag 5 speed box... I may have to change it back to a 4 speed gearbox as part of the eligability. |
Yep, that sounds just about retarded enough to be true of CAMS _________________ '80 924 Turbo |
Posted: Thu Sep 10, 2009 3:30 pm Post subject: |
send a letter to porsche, they can confirm if the car was fitted with a 5 speed, and if they do you can shove it into those guys's face _________________ https://www.the924.com |
daniel
Posted: Thu Sep 10, 2009 4:05 pm Post subject: |
Already done, they wont accept it. Pack of arogant aholes...
I just want to know whats involved in doing the swap incase I have to.
Thanks _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
Joined: 23 Jul 2007 Posts: 1076 Location: The Netherlands
Posted: Thu Sep 10, 2009 4:17 pm Post subject: |
Just get a four speed gear knob _________________ 937 trackday car
Posted: Thu Sep 10, 2009 4:22 pm Post subject: |
Dutch924-racer wrote: | Just get a four speed gear knob |
haha ! yep..i think thats a good way to keep your car as it is and trick those idiots _________________ https://www.the924.com |
Posted: Thu Sep 10, 2009 8:25 pm Post subject: |
To switch over to the four speed, you will need:
- Any Audi-style torque tube from a normally aspirated donor
- Any Audi-style shift lever
- Specifically, the shift rod & linkage from a 4-speed donor
- The 4-speed gearbox with transaxle mounts
Also, the other critical difference between the two gearboxes is that the snailshell (getrag 5-speed) mounts onto two wings on the torsion carrier. Not knowing how yours was done, I am assuming that you have the matching getrag style torsion carrier, which looks like this:
If this is the torsion carrier you have in your car, you either need to replace it with a torsion carrier from any Audi-equipped car, or you will need to cut off the two support wings (the ones in the center) that support the snailshell style gearbox. If you decide to go the replacement route, you will want to swap in the entire rear suspension assembly unless you feel comfortable dealing with reindexing torsion bars. _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Posted: Thu Sep 10, 2009 8:38 pm Post subject: |
Thanks Ideola, id rather take CAMS to court and not race then go to all that trouble and expense!
Posted: Thu Sep 10, 2009 9:01 pm Post subject: |
Yup, it's a buttload of work for sure. It's not hard, but I think your challenge would be sourcing the parts. _________________ erstwhile owner of just about every 924 variant ever made |
daniel
Posted: Thu Sep 10, 2009 9:27 pm Post subject: |
Quote: | challenge would be sourcing the parts |
This is another option for me, if I cant buy parts I can apply to have more modern parts subsituted!
Joined: 29 Jul 2001 Posts: 8794 Location: Royal Oak, MI, USA
Posted: Thu Sep 10, 2009 10:23 pm Post subject: |
Could you just change the VIN plate for a '79 or later?
Thankfully SCCA 1) just dropped the VIN rule for Improved Touring (meaning you don't even have to have a valid VIN anymore), and b) allows swapping of assemblies between different years/models if they're all classed together. So I can run any of the 3 manual trannies (that originally came in a 2.0L NA car) in my racecar, since all 2.0L 924's are classed together. Same deal with brakes; I don't have to have a car that was actually delivered with the 5-lug brakes, since they're listed as allowed, same classification line as the 4-bolt setup.
Of course, Production is another story (beknighted idiots)... _________________ Vaughan Scott
Vince Ponz
Posted: Fri Sep 11, 2009 12:10 am Post subject: |
1969 bought a new 911 and tried to join the Porsche Club the registrar asks me who recommended me. I walked away and did not join for 20 years. At that time you had to be sponsored??. [Word looks funny]
Then 20 years later I did join without the questions.
Move to florida and went to two different Porsche clubs and the same pompous asses. First question "what car do you own" Pissed me off. So I only have a 77 924 track car, a 931 79 and a 911 87 and I am still getting the 'oh you only have a 87" Forget about the 924s they don't count.
I have not joined in the past two years and I know the Pres. of the US PCA. I don't need the hassle.
Enjoy the cars. I have. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Joined: 28 Feb 2008 Posts: 1353 Location: Washington DC area
Posted: Fri Sep 11, 2009 1:36 am Post subject: |
+1 with Vince. Although I'm a 35 year member of Porsche club, I'm pretty marginalized since none of my seven Porsches are newer than 1980.
BTW, SCCA really doesn't like Porsches since they never get any factory sponsorship money like they do from Nissan, Mazda and the tire companies. My 911 got spanked in the weight department because they thougth it might be a winner (it isn't). Vaughan's car is classed properly but is still heavy by their rules. If I have as much success with my 924 as Vaughan, they will probably award us more penalty weight.
Chuck _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Posted: Fri Sep 11, 2009 3:14 am Post subject: |
How's the car coming, anyway? You gonna make it to the ARRC this year? _________________ Vaughan Scott
Posted: Fri Sep 11, 2009 4:38 am Post subject: |
No, I finished up with the 911 this past weekend. I'm doing some work and selling some parts over the next two months and then will be able to order the go fast parts for the 924. I should have it ready for the spring.
