Air filter box...
Petrovich
PostPosted: Wed Oct 19, 2005 3:58 am    Post subject: Air filter box... Reply with quote
Would OEM zealots murder me for fitting a custom foam&fiberglass airbox to a 931?... I mean, stock one is nice and all, but I want to have an ability to go to the store and buy the damn air filter, isntead of ordering it for insane amounts of money... Plus the stock steel one seems awfully heavy and grabs this very hot air right out of the radiator...
PostPosted: Wed Oct 19, 2005 5:42 am    Post subject: Reply with quote
I just run a open element cone filter up there, purolator brand, from advanced autoparts...
Petrovich
PostPosted: Wed Oct 19, 2005 7:42 am    Post subject: Reply with quote
But how do you deal with those two lines coming into the filter box?... Or do you run the box empty, and put the cone filter on the intake pipe of the filter box?...
PostPosted: Wed Oct 19, 2005 7:48 am    Post subject: Reply with quote
No, i just put filter breathers on the end of them, no air box or any left, i ripped it all out.
Petrovich
PostPosted: Wed Oct 19, 2005 7:58 am    Post subject: Reply with quote
Hm, that sounds like a good solution, actually. Where does all the oil go, btw? IIRC one of the tubes spits oil, at least mine had an oily streak on the filter box.
PostPosted: Wed Oct 19, 2005 8:25 am    Post subject: Reply with quote
Yeah, one i have open and the other just a cheap filter breather attatched to it. Nothing fancy. Id say you'd be fine by just putting a small breather filter on each line that goes into the box, possibly have to change them once in a while(2$ so not expensive).
Vince Ponz
PostPosted: Mon Feb 20, 2006 2:19 am    Post subject: Reply with quote
I use the stock filter but I cut a rectangular hole in the leading edge and a box welded it to the front and I get air from the front of the car. I have a round filter that I will modify with a tube and have it behind the headlight. I will insulate the tube because it is over the radiator. I will put it on in the spring too cold out now.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
PostPosted: Mon Feb 20, 2006 3:35 am    Post subject: Reply with quote
Actually the 931 stock air cleaner snorkle grabs cool air that is directed above the radiator.
numbbers
PostPosted: Tue Feb 21, 2006 12:04 pm    Post subject: Reply with quote
Well, my solution was to cut a big rectangular hole in the lower half of the stock box, and remove the snorkel, and put a metal plug in where I removed the snorkel. All fo the air now comes in from the nose grills, straight into the box. That, and the addition of a K&N, made a big difference.
Keaton
PostPosted: Tue Feb 21, 2006 5:21 pm    Post subject: Reply with quote
numbbers, do you have any pics??
numbbers
PostPosted: Wed Feb 22, 2006 10:58 am    Post subject: Reply with quote
Yes, I have pics, I have just never figured out how to post them.
J1NX3D
PostPosted: Wed Feb 22, 2006 11:20 am    Post subject: Reply with quote
email it to me numbbers, I'll post it for you
mad924@orcon.net.nz
'86 944
J1NX3D
PostPosted: Sun Feb 26, 2006 3:00 pm    Post subject: Reply with quote
That is one sexy beast numbbers!
'86 944
Khal
PostPosted: Sun Feb 26, 2006 5:19 pm    Post subject: Reply with quote
Damn! That's one of the cleanest 924 engines I've ever seen!
'80 924 Turbo
numbbers
PostPosted: Tue Feb 28, 2006 10:30 am    Post subject: Reply with quote
Thanks, the whole car is that clean.
