Fuel Mixture
Roger Hall
Guest
PostPosted: Mon Jan 14, 2002 9:52 am    Post subject: Reply with quote
My 81 924 seems to be running lean. I read the Haynes manual and it describes how to adjust the fuel mixture. I know that you need a gas analyzer according to the book but I just wanted to richen the mixture a little to see if it helps. Shop has checked the mixture I am just running out of things to try.
numbers
Guest
PostPosted: Tue Jan 15, 2002 9:06 am    Post subject: Reply with quote
A lean condition in these cars is usually caused by a vacuum leak, not a mixture problem. Adjusting the mixture just masks the real problem. If you want to verify the lean condition, take your car in for a smog check. If you are running lean, you NOX will probably be high. If you are running rich, your hydrocarbons will be high. You can also buy a mixture guage that works off of your O2 sensor for about $15.00.
Roger Hall
Guest
PostPosted: Tue Jan 15, 2002 1:17 pm    Post subject: Reply with quote
I replaced most of the vacum lines, and one of the boots. I have not tested the system though. I will take your advise a vacum test is simple and cheap. In the manual it says that there should be a rubber plug over the mixture adjustment opening. Could there be a vacum leak from the mixture adjustment opening? Guess I will find out.
-nick
Guest
PostPosted: Wed Jan 16, 2002 4:28 am    Post subject: Reply with quote
the rubber plug isn't supposed to be air-tight. it just keeps debris out. if you do adjust the mix keep in mind that a very small twist on the adjusting screw changes the mix considerably. an 1/8 of a turn one way or the other is usually all that is needed.
btw- those air/fuel mixture gauges aren't really precise enough to tune by.
regards,
-nick
Joes924
Guest
PostPosted: Fri Jan 25, 2002 1:57 pm    Post subject: Reply with quote
I welded the oxy sensor closed last summer when I replaced everthing behind that with straight 3"pipe and a glasspak with the resonator welded tothe end ... I was looken at some site the other day and saw a oxy sensor kit with the attachment to the same thing on the pipe and it was a naet little unit..I think 2 lights one red the other green 1 being rich the other being lean when they both lit up you were dialed in for
$ 150..0 I think i wouldnt mind haven one .
