Joined: 01 Jan 2003 Posts: 8030 Location: DE (the one near MD, PA, NJ)
Posted: Thu Jun 12, 2008 6:32 am Post subject: |
I happen to have my old head bolts laying around. The thread is M12x1.75, length with the washer in place is 110mm, and length without washer is 114mm (washer is 4mm thick ). Overall length including the head (hex socket head) is 126mm (12mm head length).
Info stamped into the head is "M12 - INBUS 10.9". _________________ "..it's made in Germany. You know the Germans always make good stuff."
bass gt
Posted: Thu Jun 12, 2008 6:43 am Post subject: |
Smoothie wrote: | length with the washer in place is 110mm, and length without washer is 114mm (washer is 4mm thick ) |
thank god you helped me, i was running out of fingers and toes
I will call Arrow tomorrow and get the ARP part number.
Because i love you all so much  _________________ Front Wheel Drive is the Devil's work. |
bass gt
Posted: Thu Jun 12, 2008 6:44 am Post subject: |
Smoothie,
Forgot to ask. What is the length of the bottom thread? i will need this too
Posted: Thu Jun 12, 2008 6:54 am Post subject: |
Yeah, I don't have the worksheet yet, but I suspect they will want the depth of the threaded hole in the block. _________________ Toofah King Bad
- WeiBe (1987 924S) - 931 S3
Posted: Thu Jun 12, 2008 6:56 am Post subject: |
I noticed you asked for the "bottom diameter" before, now the "length of the bottom thread".. Assuming by length you mean the length of the whole threaded section, my trusty calipers say 33.4mm. -And for the diameter of the first thread I get 11mm (caliper over the rest of the threads shows 11.7mm).
Washer ID is 12.5mm, OD is 23mm, thickness as mentioned before is still 4mm.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
bass gt
Posted: Thu Jun 12, 2008 7:02 am Post subject: |
Smoothie wrote: | I noticed you asked for the "bottom diameter" before, now the "length of the bottom thread".. Assuming by length you mean the length of the whole threaded section, my trusty calipers say 33.4mm. -And for the diameter of the first thread I get 11mm (caliper over the rest of the threads shows 11.7mm).
Washer ID is 12.5mm, OD is 23mm, thickness as mentioned before is still 4mm.  |
Smoothie, thanks. i was close at M12x1.5!! So, 34mm from bottom of bolt to top of bottom thread(if that makessense) leaves (wait, err 6, 5,8&3-2+44=) 80mm for shoulder to the bottom of the head.
Hopefully be back tomorrow with the info. _________________ Front Wheel Drive is the Devil's work. |
-nick
Posted: Thu Jun 12, 2008 7:59 am Post subject: |
Ah, this is an oldy. I ended up going Smoothie-style and cut a notch out of the tops of the studs with a dremmel so that I can just use a flathead screwdriver to twist them in and out. Works like a charm. _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Thu Jun 12, 2008 10:38 am Post subject: |
Here be the ARP worksheet:
Posted: Thu Jun 19, 2008 2:28 am Post subject: |
Awfully close here. . .anyone? _________________ Toofah King Bad
bass gt
Posted: Thu Jun 19, 2008 2:51 am Post subject: |
Rasta,
Sorry, been up to my ears in it at work. I have spoken to the Guy's at Arrow, and should have the info/ part number by tomorrow.
One thing i need checking though please. Looking at the details supplied, 1.5 seems to be very fine for a bolt of this size. I would expect it to be 1.75 pitch. Can someone remeasure and confirm this lower pitch size for me. Looking at the Ford items, they all run 1.75 so it seems logical that it should be that.
Posted: Thu Jun 19, 2008 7:42 am Post subject: |
Absitively someone else measure to confirm, but Steve, I think you're actually the only one that's suggested it might have been a 1.50 pitch, right?
Smoothie wrote: | The thread is M12x1.75, |
bass gt
Posted: Thu Jun 19, 2008 9:16 am Post subject: |
Smoothie wrote: | Absitively someone else measure to confirm, but Steve, I think you're actually the only one that's suggested it might have been a 1.50 pitch, right?
Oops mea culpa. it's me getting my wotsits in a tiswas!! Well that makes it easier. OK, so the pitch is definatley M12x1.75. That is a Ford fitment, so it should be a snap. Spoke to the guy today, but he has not had a chance to check. Promised me a reply tomorrow, however, i'm flying to Johannesburg, South Africa tomorrow evening, so i might miss his mail. Worst case, I'm back Tuesday evening, so hopefully will be able to post the ARP part number then. hold tight chaps
Posted: Thu Jun 19, 2008 9:18 am Post subject: |
Didn't mean to get you thinking it was some huge rush, Steve. I appreciate your help, and your own schedule is fine by me.
Posted: Thu Jun 19, 2008 10:32 am Post subject: |
So is there a group buy happening here? |
macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Thu Jun 19, 2008 11:15 am Post subject: |
I'll get some, my engine is coming out soon. _________________ 1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways  |
