-nick
Posted: Fri Mar 10, 2006 4:38 am Post subject: |
No fight, just learnin' something new
ps- my "pup" is at a distinct disadvantage since she can only see when the wind blows the hair out of her eyes... Although, Smoothie's pup might be so embarrassed about having to wear that flannel that he'll just forfeit. heh heh.
nick |
Chrenan
Posted: Fri Mar 10, 2006 4:50 am Post subject: |
My granparents neighbours had a sheep dog when I was growing up (I think that is what your's is), had to be the friendliest dog I have ever known, which was a little intimidating given the size. _________________ 1987 951 - M193 Version for Japan |
D Hook
Posted: Fri Mar 10, 2006 1:16 pm Post subject: |
Hey! My dog in my avatar is getting jealous! (I don't let him drive anymore since he almost got busted for speeding in a construction zone.)
Chrenan: If I send you my engine, will you spiff it up like yours. Man, that sure looks good. _________________ '80 924 n/a SOLD |
Posted: Fri Mar 10, 2006 1:54 pm Post subject: |
I've always wondered if this hole was for a mechanical fuel pump for the carb version of this motor....
_________________ White 87 924S "Ghost"
Chrenan
Posted: Tue Mar 14, 2006 10:58 am Post subject: |
More minor progress, distributor housing...
Posted: Tue Mar 14, 2006 11:57 am Post subject: |
lets see got the high cp pistins larger valves n stiffer springs and even a performance
cam this may be a dumb question though anyways here tis .. you are going with a performance header right ?? _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Chrenan
Posted: Tue Mar 14, 2006 12:29 pm Post subject: |
It's a good question. I have been going back and forth on whether or not to buy a performance header. I've heard different stories, the stock one is fine, a performance one could help, performance ones are prone to cracking, etc etc etc. I still haven't decided what to do. _________________ 1987 951 - M193 Version for Japan |
Mike924
Posted: Tue Mar 14, 2006 6:10 pm Post subject: |
Paul wrote: | I've always wondered if this hole was for a mechanical fuel pump for the carb version of this motor.... |
Pretty sure that's what it's for. _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
1993 Porsche 968 Coupe, Midnight Blue, 6 spd
'There is no substitute for a little grease under your fingernails.' - Chrenan, 924board.org |
Slam
Joined: 07 Jan 2005 Posts: 1689 Location: Wainwright, Alberta, Canada
Posted: Thu Mar 16, 2006 4:12 pm Post subject: |
Looks good to me.
How common are oil leaks from the back of the cam cover, where the distributor housing is? I know it's a problem on some 944s, and our 924 seems to be leaking there too. _________________ '84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably |
Chrenan
Posted: Fri Mar 17, 2006 1:00 am Post subject: |
I'm pretty sure I have an oil leak there on my 1980, and the engine I took out of the 77 appeared to have an oil leak in that spot too. That being said, I didn't do anything different in the assembly that I think would stop it. Gasket sealer, gasket and appropriate torque. Maybe there is some design flaw or issue with heat at the back of the engine that causes the gasket to fail sooner. _________________ 1987 951 - M193 Version for Japan |
Posted: Sun Mar 19, 2006 6:47 am Post subject: |
Yeah those rubber gaskets that go at the front and rear of the cam cover can use an extra dollop of gasket sealer at each end wher the flat meets the round cutout... I think the cam cover gaskets that go along the sides are not built up enough where they meet the other rubber gasket and you get a small opening there.
Leadfoot _________________ 1981 ROW 924 Turbo -
Chrenan
Posted: Mon Mar 20, 2006 12:51 pm Post subject: |
More minor progress, rear coolant housing installed. I'll change out the thermo time switch and temperature sensor with the new items when they arrive...
Chrenan
Posted: Sat Mar 25, 2006 2:38 pm Post subject: |
More minor progress, thermostat housing and camshaft oil seal installed...
Chrenan
Posted: Sat Apr 01, 2006 1:05 pm Post subject: |
More minor progress, cam sprocket installed and valve cover installed. Of course, I'll have to lift the valve cover to install the head bolts, but I figured I'd get the gaskets laid and everything buttoned up for now to keep things clean. Sealant only on the bottom of the valve cover gaskets in any case, so getting it off is no problem...
Kenodog
Posted: Sat Apr 01, 2006 4:46 pm Post subject: |
No adjustable cam gear ? _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
