Chrenan
Posted: Mon May 15, 2006 9:11 am Post subject: |
Cold start valve:
Injectors:
Clutch cable bracket:
Bleeder hose:
_________________ 1987 951 - M193 Version for Japan |
timstar92404
Joined: 22 Sep 2004 Posts: 2075 Location: richmond BC
Posted: Mon May 15, 2006 1:26 pm Post subject: |
are you going to use your 924 as a daily driver after this? _________________ 78 924 sold.
85.5 944 |
Chrenan
Posted: Mon May 15, 2006 1:37 pm Post subject: |
No, it will still be a summer hobby car. I like being able to insure it for $125 a year under a collector policy, and that excludes using it as a daily driver. _________________ 1987 951 - M193 Version for Japan |
Chrenan
Posted: Mon May 29, 2006 12:50 pm Post subject: |
Well, me and a friend started at 10:00 this morning and I came in at 8:00 this evening. Pulled the old engine and installed the new. Lots of little details taken care of, new motor mounts, new starter, new clutch disk, pressure plate and throw out bearing, new fuel line to the bottom of the fuel filter, and some other things I am probably forgetting. Feels good to get it in place. Unfortunately I won't have time for a few weeks to get back to putting the fuel, cooling and electrical together. Still, it was a big step today, worth a picture and an update...
Posted: Mon May 29, 2006 3:53 pm Post subject: |
Great build with pics and all. I cant see why you wont get a header
have you ever had one. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Chrenan
Posted: Tue May 30, 2006 12:59 am Post subject: |
CBass wrote: | Stock exhaust manifold isn't that bad once it's gasket matched at the downpipe. There's usually a ton of weld around the inside of the DP which doesn't help either. I certainly think it's good enough for anything you're going to see out of a 7000rpm 2.0 924. |
Chrenan wrote: | I kept going back and forth on a header, maybe I should, maybe I shouldn't. Same with the lightened flywheel, maybe I should maybe I shouldn't. The longer term plan is to stroke the bottom end that is in the car currently and combine it with the bigger valve head, that incarnation will likely get further upgrades, lightened flywheel, electronic ignition and fuel injection. The electronic fuel/ignition is the one area where I know zero, so that should be scary. |
Joe, mostly for the reasons above... _________________ 1987 951 - M193 Version for Japan |
Chrenan
Posted: Tue May 30, 2006 1:02 am Post subject: |
A quick note on engine installation, wasn't too bad a job, a little tricky.
I couldn't imagine doing it without using the factory lift points that attach to the intake manifold bolts. Hooking the hoist onto those lift points keeps the egine nice and level at just the right slant to install. Once we got a few bellhousing bolts started, it was clear sailing. _________________ 1987 951 - M193 Version for Japan |
sequential
Posted: Tue May 30, 2006 1:18 am Post subject: |
The lighten flywheel is a must , also did you upgrade the factory camshaft?
did you stroke the engine? What CR ?
there is no way the stock manifiold will flow like an MSDS header, or a good tri-y header ( piper i think ) look at the 924 cup cars out of the UK there is some parts there you can use... _________________ 928 gts prototype
baby blue engine block
steam in 1,2,3,4 sometimes
cold star issues while on stands
112 whp with new 4 valve head and MIS 2 |
Chrenan
Posted: Tue May 30, 2006 1:40 am Post subject: |
Euro pistons, 9.3:1 compression. Stage 1 cam from Euro Race, still a pretty mild profile so I can retain CIS for now, recommended match for their big valve head while retaining stock injection. Didn't stroke or increase bore, I may eventually do that with the engine that just came out of the car. _________________ 1987 951 - M193 Version for Japan |
sequential
Posted: Tue May 30, 2006 4:13 am Post subject: |
Does anyone have a web site or phone number for Eurorace .... _________________ 928 gts prototype
Chrenan
Posted: Tue May 30, 2006 4:48 am Post subject: |
Euro Race (as it was called in the 80s) is now European Motorworks, ask for Jorge:
(310) 644-8038
(800) 722-8678 (in the US)
http://www.europeanmotorworks.com/ _________________ 1987 951 - M193 Version for Japan |
Posted: Tue May 30, 2006 7:42 am Post subject: |
Eurorace adjustable timing gear 8v
Part number 059.101
$89.00 _________________ White 87 924S "Ghost"
Chrenan
Posted: Tue May 30, 2006 7:52 am Post subject: |
Hmmm, never noticed that before. That must be wrong, according to the housebrown thread from a few months ago, you can't produce and profit (even slightly) from an adjustable timing gear at less than something like $300. _________________ 1987 951 - M193 Version for Japan |
Meneer aard
Posted: Tue May 30, 2006 7:00 pm Post subject: |
Did you first clean your engine bay before you put the engine in the car? _________________ Porsche 924 Euro 1977 |
Posted: Tue May 30, 2006 7:50 pm Post subject: |
Makes no sense not to get a mds header. _________________ 1979 porsche 924 Na
