EFI Bolt On Kit
Goto page Previous  1, 2, 3, 4, 5
PostPosted: Sat Apr 21, 2007 6:45 am    Post subject: Reply with quote
CBass wrote:
I wonder if the 944 casting would fit...If you have a 944 body that you can measure, that would be awesome!
No need to measure. I have a 924S intake complete with TB as well as a 931 S2 intake complete with TB. I just confirmed that the 924s/944 TB is a direct bolt-on to the S2 intake manifold. Sweet!
Raceboy
PostPosted: Sat Apr 21, 2007 3:19 pm    Post subject: Reply with quote
Good news, but 924S/944 has on/off type TPS not variable resistance that is needed for standalone engine management system.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
PostPosted: Mon Apr 23, 2007 5:49 am    Post subject: Reply with quote
If anyone is interested, I have two or three 2.2 Turbo one fuel rail, injector and regulator setups here. The regulator on the T1's are separate so they are easier to adapt. The Injectors are the same physical dimensions as the ones CBass posted (standard GM/Bosch pieces used on many US cars at the time)
Like I posted in another thread, the 1st generation Ford Escort (with the 1.9L CVH High Output engine) used a 2-piece intake that could be used on a 924 (after some port matching) and redrilling some holes. Since 1.9L EFI cars are about as unloved as turbo ones they are cheap and easy to find and part out.
I'll work on getting the intake fabbed up on a spare head I have and take some pictures.
As to the EFI "kit" I'd suggest just providing the instructions and a wiring harness and let the buyer source their own parts, much like the original MegaSquirt kits. B&G supplied the bare circuit boards and provided instructions and a parts list. As has been discussed already there is more than one way to skin the EFI "cat" depending on where in the world you are and what your skillset is, so the kit needs to be flexible to deal with those realities.
TTYL,
endwrench
PostPosted: Mon Apr 23, 2007 1:12 pm    Post subject: Reply with quote
Stefan,
Are there any hood clearance issues with the escort intake?. I seem to remember they are basically U shaped tubes to the plenum. The plenum is kinda small too.
Todd
PostPosted: Mon Apr 23, 2007 2:14 pm    Post subject: Reply with quote
I'm gonna look into that, I've only gotten far enough to determine that it will match up pretty close. I'm thinking that it may need to be mounted upside down which will make some things difficult (like injector R&R)
Yeah, the plenum is a little small. I think the later model 2.0L CVH dual path intake is a little better, but I don't have one to test with just yet.
HappyPuppy
PostPosted: Fri Dec 07, 2007 2:35 pm    Post subject: Reply with quote
I know this may get overlooked, but I've been piecing together the parts for my 931 EFI conversion for a while, and have made an interesting discovery.
The fuel rail from a Mercedes SLK 230 Kompressor lines up with the injector holes on the 931 pretty well, and the injectors themselves, with some careful drilling, will slide into the small section of the injector hole almost all the way flush to the ceiling of the intake port.
I have not drilled out my holes yet--that was based on careful measurement. I also have no idea what the fuel pressure setting of the regulator is or the flow rate of the injectors, but seeing as its coming from a supercharged 2.3L 4-cylinder, it's probably more than adequate.
My frequent desire to perform violent acts on select other drivers is not road rage; it is simply preemptory self-defense.
Page 5 of 5
