Clutch pedal stays on floor...
Johnny_924S
Guest
PostPosted: Thu Nov 29, 2001 2:11 am    Post subject: Reply with quote
Hey I think I need to replace my clutch slave cylinder because its leaking.... anyway I went out to my car and hit the pedal and..."SHOOP" right to the floor and it wouldnt come up, now i have to bleed it and change it (not in that order) anyway i was wondering if anyone has done that or if anyone has one for sale that will fit an 87 924S. Thanks, Johnny
marky522
Guest
PostPosted: Thu Nov 29, 2001 3:00 am    Post subject: Reply with quote
Word to the wise, if you do the slave do the clutch master (i dont know if i said that right) anyway do both of them in the clutch system, if you dont i give you one week before you are back under there doing the other i wasnt fortunate enough to hear this before i did it. Good Luck
Mark
Zuffen
PostPosted: Thu Nov 29, 2001 3:21 am    Post subject: Reply with quote
9 out of 10 times the slave is the bad part and the master is ok, plus the master is a bitch to get to. Just change the slave, flush and bleed the brakes and clutch circuit.
You might check the clutch and brake master by crawling under the dash and looking for seepage on the firewall.
Bob Dodd - 924turbo@cox.net
