Well what is it going to be? |
Build it and start selling them already!!! |
58% |
[ 24 ] |
Keep it to yourself and step away from your tools |
9% |
[ 4 ] |
I want one |
21% |
[ 9 ] |
I don't want one, make mine a double, give me 2 |
4% |
[ 2 ] |
Drop the Color, I dont want no stinkin' color |
2% |
[ 1 ] |
Give me more colors, lots of colors |
0% |
[ 0 ] |
What were you thinking? Just one more thing for me to spend money on thanks alot! |
2% |
[ 1 ] |
Total Votes : 41 |
Posted: Tue May 31, 2005 4:48 pm Post subject: |
Cool ,, good work. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
ESC944
Posted: Tue May 31, 2005 4:58 pm Post subject: |
An acceptable situation would be to even see the unit spool up fast, then peak then drop slightly at redline, moving you max boost to slightly below redline, to reduce stress on the engine.
You would still have boost, just it would be on its way down. So say 3+ at 1k, climbing fast to a peak holding at 8 PSI till 5500 rpm, then dropping to say 5 PSI at 6500 rpm. It would all be a manner of tuning. Not to hard to do, but you have to overcome the limits of typical drive components. The impeller and shaft are not the issue, its anything that drives those to make your boost.
One thing a roots can not do is hit the high boost levels of a centrifugal. SO if geared right you can make 10, 20, 30 even 40 or more PSI, provided the engine could handle such levels. High efficiency, low heat and insane boost capabilities, now someone go build an 924 engine that can handle those levels. HAHAHA
Now this is where my madness shows… being a space balls fan, I would have to label my override button “ludicrous speed”. If you don’t get the humor, man that’s a terrible shame….
Posted: Tue May 31, 2005 7:08 pm Post subject: |
Nice work, I can see a few people lining up for one... must have taken a while to work out the gearing...
Are you running a seperate oil line for it??
Leadfoot _________________ 1981 ROW 924 Turbo -
Helstrm
Joined: 05 Feb 2005 Posts: 198 Location: Columbia, SC
Posted: Wed Jun 01, 2005 12:27 am Post subject: |
Quote: | Now this is where my madness shows… being a space balls fan, I would have to label my override button “ludicrous speed”. If you don’t get the humor, man that’s a terrible shame…. |
As long as you don't go too fast... Once you exceed ludicrous speed you will go plaid (sp)? |
924guy
Posted: Wed Jun 01, 2005 1:48 am Post subject: |
lol, i just picked up a copy of spaceballs on vhs at a yard sale recently, the whole "going plaid " things cracks me up...
ESC.. please let me know when i can get that other door from you, im going to start prepping the first one shortly for repaint and would like to do both at the same time.. maybe ill take a trip down your end, and you can show off your toys  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
ESC944
Posted: Wed Jun 01, 2005 2:17 am Post subject: |
924guy, dude I will be going up your way in the next week or weekend going to Orlando, so I can swing by and drop it off or meet you at the exit ramp or something. I will have the family with, going up to look at some houses.
Leadfoot -- It is self contained at this time, but I am thinking of a oil system for sustained high boost and subsequently high bearing and shaft speeds and related heat.
Primary testing on the ALPHA unit was at a max of 12 PSI, but that is no where near the limits.
That would yield 4.4 PSI at 3250 engine RPM… and should in theory yield 2.2 PSI at 1625 RPM, that is of course depending on the principal that as you half engine rpm, boost drops by its square root.
ESC944
Posted: Tue Jun 07, 2005 1:37 pm Post subject: |
endwrench
Posted: Tue Jun 07, 2005 2:38 pm Post subject: |
So what is the difference between the blue and green runs? I assume the red is stock.
Todd |
Joined: 01 Jul 2004 Posts: 3153 Location: Eau Claire, Wisconsin
Posted: Tue Jun 07, 2005 3:27 pm Post subject: |
Those red numbers still seem a bit high for a stock 924 2.0 n/a _________________ [This Space For Rent] |
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Tue Jun 07, 2005 4:17 pm Post subject: |
flosho wrote: | Those red numbers still seem a bit high for a stock 924 2.0 n/a |
the dyno sheet says 944  _________________ '86 944 |
ESC944
Posted: Tue Jun 07, 2005 10:04 pm Post subject: |
The Red is the baseline for a 2.5 Liter. Rear wheel Horsepower.
The diff between the other two runs is higher boost level.
Keep in mind that the 944 I tested is not mine and was not stock. Most of the stock 944 NAs I have seen max rear wheel is around 131-133 hp. With Peak Torque of 133-136. All at the rear wheels.
I will post some other runs tonight, not nearly as impressive, but they are decent, shows what can be done with different pulley ratios.
In the runs you see, I was making boost at 2000 RPM, spooling up quickly and then venting once I hit max boost. Technically I was seeing boost below 2000 RPM, not much but it was there. |
ESC944
Posted: Wed Jun 08, 2005 12:15 pm Post subject: |
Wow everyone is so quiet... hemmm.
Guess I will have to do a poll and see who is interested... if I should build these and sell them or what. |
Helstrm
Posted: Wed Jun 08, 2005 1:28 pm Post subject: |
How much do you think the kit will end up costing? |
maireeka
Joined: 29 Aug 2004 Posts: 299 Location: North Alabama
Posted: Wed Jun 08, 2005 4:16 pm Post subject: |
brilliant work! I'd love to spank a 931. _________________ 1977 Porsche 924 red and READY! |
Posted: Wed Jun 08, 2005 8:36 pm Post subject: |
been busy...working and surfing...
The figures are looking good although charts look a little peaky.... are there some fuel or belt slip issues??....
Or is this how centrifugal superchargers look on the dyno.
It's funny how from stock the hp curve just moves up the range with little change to hp dips and peaks.
One would think that with boost applied the dips in airflow are minimised somewhat.
I'd give your system a try but I'm quite happy with the one I've got at the moment. Anyway it will prove a good comparison when you finally fit one to a 924 N/A.
P.S I like red.... Bright orange would be cool too...
