Camber, Castor and tracking
Mark CSC
PostPosted: Thu Nov 22, 2001 12:30 am    Post subject: Reply with quote
Has anybody got the figure for what the above should be? Also I was told that when doing the tracking camber and castor should also be done as well. Is this true???
Mark
'83 NA
[edited as I kan nit spall]
[ This Message was edited by: Mark CSC on 2001-11-22 01:31 ]
PostPosted: Tue Nov 27, 2001 2:52 am    Post subject: Reply with quote
Sounds like you need an alignment, maybe? This is generally done by a shop. I suggest that you have it done through a dealer, all 4 wheels, since the rear suspension is Porsche-specific, requires special tools, and is easily screwed up by idiots. The dealer will either do it correctly themselves or have it contracted out to a good shop.
Factory specs are quite fine for the road.
