Volt Meter
Blas Costagli
Guest
PostPosted: Sun Nov 18, 2001 12:55 pm    Post subject: Reply with quote
I have acquired a NOS Volt meter for my 1979 924 and plan to finally replace the air conditioning switch with something I can use.
Can anyone tell me how the Volt Meter is installed at the factory? The meter has 2 Black wires connect together at the plug along with a Brown wire also on the plug. (I assume this is the ground) I would like to install it as it was originally supposed to be installed.
Thanks all.....
[ This Message was edited by: Blas Costagli on 2001-11-18 13:56 ]
