squeeky rear hatch
jamez
PostPosted: Sun Nov 04, 2001 11:14 am    Post subject: Reply with quote
hey, Im sure you guys have talked about this before, but does anyone have advice on how to stop a squeeky hatch?
eturbo924
PostPosted: Mon Nov 05, 2001 11:03 pm    Post subject: Reply with quote
Two things to try. One replace the rear hatch seal.... thus making the hatch tigher fit. The other is to adjust the hatch latches so that you much push down on the hatch to make it latch.... again making the fit tighter.
Eric
numbers
PostPosted: Wed Nov 14, 2001 7:39 am    Post subject: Reply with quote
Also, check your hinge mounts. The bolts may be loose.
PostPosted: Mon Nov 19, 2001 5:04 am    Post subject: Reply with quote
If it's the rubber seal that's squeeking, use some silicone lube on it. That will of course lubricate it and silicone is actually good for rubber vs. petroleum based lubes.
