swicks Guest
Posted: Sun Aug 19, 2001 4:20 pm Post subject: |
I recently melted my motor (XJ spec) and have bought a second hand (XK spec.
I have two questions - what is the difference between the two (I think they are both Euro spec)?
Secondly, I am going to rebuild the XJ motor. I will balance crank, rods, pistons etc and match all the manifolds to the ports. I would also like to fit bigger valves and enlarge the ports slightly. Does anybody know what valves could be used? I do not want a wild motor, but would like to get to about 140-150 bhp, what else should I do? |
Dave Guest
Posted: Mon Aug 20, 2001 2:58 pm Post subject: |
Go to http://www.HuntleyRacing.com These guys know alot. You could write them or call them up. They are good guys and help me with my 924S alot. So give it a try and let me know how it works out.
larso Guest
Posted: Tue Aug 21, 2001 3:46 am Post subject: |
well the 931 valves are a lil bigger.
Disadvantage with bigger valves is that the stems are bigger and the flow gets restricted. Try and keep the valve stems skinny with strong material.
Ive never looked at a 924 valve compared to a 931, I've just seen a 931 valve, so I am not sure if the valve stems are the same size and the valve head is just bigger.
I don't like the idea of 931 valves because they cost twive as much as 924 valves. 50 bucks a peice compared to 25 bucks a peice. |
quasirogue
Posted: Mon Jun 03, 2013 12:59 am Post subject: |
yes
Posted: Mon Jun 03, 2013 8:34 pm Post subject: |
Holy dead thread, batman. _________________ erstwhile owner of just about every 924 variant ever made |
