One high beam not working
jebe
PostPosted: Fri Dec 03, 2004 2:18 am    Post subject: One high beam not working Reply with quote
Now I discover the next thing; only the left high beam is not working (low beam both work). Threw in a new bulb, contacts of the block looked ok (on sight, and contact sprayed) as did the cluster of grounds at the light (on sight, and contact sprayed), placed new fuses (nr 3 & 4). Fumbled wires at the light with high beam switched on. No effect.
If you suggest to 'trace the wiring' I know it'll mean horror to a non-electrical guy like me, as it is so impossible without tearing up good wiring covers, take away engineparts I never moved, not to speak of the impossible spaghetti under the dash, I'll get lost in (but also on sight everything looks fine, like new, no rust, corrosion etc. at all)
So anybody has clues I can check, or are there specific places to check (besides the once mentioned above)? Would be great!!
TNX
Jeroen
924S/1988
Darin81T
PostPosted: Fri Dec 03, 2004 4:09 am    Post subject: Reply with quote
It might be the connectors that plug into the back of the fuse box. I don't have a diagram handy, but if memory serves correctly, the head lights are on the white connector and on the ivory connector(1st & 3rd I think), I can't remember which pins though. Unplug those connectors and clean them up and see what happens.
Later,
Darin Flynn
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
CMXXXI
PostPosted: Fri Dec 03, 2004 5:49 am    Post subject: Reply with quote
I just installed some new Hella H4 conversion lights and had a similar problem. My left low beam didn't work. Swapping the bulbs around proved the bulb to be good, and a multimeter showed that the light was getting 12 volts like it should. Turned out to be that the fuse wasn't passing enough current. I removed the fuse, lightly sanded it's contacts and it's seats, reinstalled the fuse and "spun it" a couple times and everything worked. Even though with a visual inspection it looked good, there was just enough corrosion/oxidation to keep if from working.
'79 Eurospec 931
Eturbo924
PostPosted: Fri Dec 03, 2004 7:39 am    Post subject: Reply with quote
That is what I was going to suggest. Always remove the fuse and inspect it. Corrosion can cause to much resistance and also.... some times the plastic actually melts and the fuse does not blow... but the end no longer makes proper electrical contact. So replacement is nessesary.
Always remove the fuses.
1992 968
2003 C4S
Parts Parts Parts and More parts.
E-mail me for parts you need!
Drive Fast!
jebe
PostPosted: Fri Dec 03, 2004 8:05 am    Post subject: Reply with quote
already changed fuses, connectors ok, what else could it be?
PostPosted: Fri Dec 03, 2004 8:35 am    Post subject: Reply with quote
If you have access to a volt ohm meter, check for 12V at the headlight connector.
If you do not have 12V, shutoff the lights and do a continuity check from the fuse to the headlight connector. To do this, unplug the light and remove the fuse. Then check for zero ohms from the fuse holder to the headlight connector.
